Dual Pass intercooler
#226
I have the Diagram but not Uploaded, But it's easy Starting at the Pump, The Pump is Mark in & Out or at least Mine was! The Out Port on the Pump goes to The Stock H/E IN>>>>Then to Your Dual Pass IN If you have a 2nd H/E>>> Then Out of the H/E to the IN Port on the Dual Pass Endplate which is the center 1>>>>> Then out of the Dual Pass upper & Lower outlets with a short piece of hose >>> Then Connect your 1st tee Making the 2 out Ports 1>> Then a Short piece of Hose again & connect the next Tee >> 1 Outlet of this Tee goes to the New Reservoir & The last 1 goes to the Pump IN! Done
Then take the Plug off the Top of your stock H/E & Run a 1/4 inch Line to the Reservoir inlet with a .40 orifice in the Line to Slow the Flow!
Crate engine Depot has the Details & Diagrams on the Install!
#233
The stock fill neck goes away when you do the Option B tank right? the Tee goes where the current neck is and that line runs to the tank. then the 1/4" line runs to the stock HE nipple right?
#234
1 Post
I plan on doing exactly this but with a twist. the reservoir will be included in the circulation with a port in the side for in and out the bottom to the pump. bleeding off the air from the HE will have to be intermittent most likely but will work.
#240
Last when you fill the system, You fill it the the Reservoir! So if it didn't drain or circulate with the system why would you fill thru it?
#244
Dude it's the way the Option B works! You get rid of the neck you have (Which is your stock so called Reservoir or exspansion area) & replace it with a Tee Then run 1 side to the Reservoir! I've been running this since it came out, It's all been discusssed thru this Thread! just look back a couple Pages!
#246
Did you check to make sure the Inlet & outlet were connected right & that the Tees were on right? Me & LsjPuP are running it, He drives his car every day & has absolutely No Problems! I drove my car to the station & Home, Then refilled it & did it again! Now it maintains half full all the time Or Half empty how ever you want to look at it!
#247
My level was ok, but there wasn't flow through the manifold. If I full-throttled second and third, I would see boost over 19-20psi, and the car would pull timing. Now, its back down to 17psi and running strong. I like the auto-bleeding idea, but I'm not sure why it wasn't working for me. I had the same setup you do.
#248
#250
1) If you have the stock endplate it wont work(Dual pass endplate requried)
2) The center Port is the in from H/E or H/Exchanger's!
3) The top & Bottom ports get tied together with the 1st Tee
4) Then a small piece of Hose, Then the 2nd Tee(Which is the 1 that takes the place of the stock Neck!
5) 2 ports left on the Tee 1 goes to the New Reservoir & the other goes to the Pump for the return trip thru the H/E
6) the 1/4 inch line goes from the top of the stock H/E to the 1/4 inlet port on the Reservoir!
Done!
Oh & don't forget to change your laminova's around or it wont work!
