e85
I was able to get it there using the 60s i had it leaner..... 12.3-12.5 no kr idcs of 95% of course i told him to get 80s lol........... .Ut if i were to say go down to 11.5-11.8 i would have been 100+% idc/B]
You MIGHT be able to get away with a 2.7" with the winter E70 or spring/fall E78. But a 2.7" is too much for full E85.
Here is my car on a 2.9"/60s/E85/I/E ect...
Works for me!
E
I really like the 2.9"/60s/E85 setup. Its a good size pulley for almost any level of modified LSJ and with a good E85 tune, it will make a lot more power then most guys running smaller pulleys with gasoline.
Works for me!
E
It should be noted that extensive testing has shown a diminished rate of return in the use of high levels of E85 in FI vehicles.
https://www.cobaltss.net/forums/2-0l...tuners-232430/
Basically, HP tunability and KR resistance does not increase drastically past an E50 mix. Theoretically, and LSJ should be able to make as much hp with E50 as E85. So really, 60# injectors could probably handle a 2.6" pulley with a custom Ethanol mix.
Personally, I wish the Ethanol fuel distributors would run the same blend of Ethanol and gasoline all year long. I would be more then happy to run anywhere from an E50-E70 blend and get some of my fuel economy back.
Macgyver2484
09-02-2015 05:44 PM
