Ecotec 2.0 LDK swapping into a 240SX S13
Old 08-10-2017, 08:44 PM
BurnNrubberSS's Avatar
Cut the support to get the swap in and out fast and easy Looks damn good in the 240
Plenty of room on this side for a custom turbo manifold and a bigger turbo
Old 08-10-2017, 08:50 PM
Sits a little high
So the top of the valve cover is 4 1/2" taller then the top of the hood so my options are to ether cut the hood and make a 5" hood cowling or option 2 cut and modify the oil pan and pick up tube.or option 3cut and modify stock k-member. Or buy a tublar k-member and hope it gives me enough room
Old 08-12-2017, 04:40 AM
Crav3's Avatar
A custom oil pan would be the way i would go. 5" cowl hood wouldnt look good on an s13 imo. Unless the tubular k member has more space for the stock oil pan. Maybe get one made similar to the one ecotec miata makes?
Old 08-12-2017, 03:32 PM
Sharkey's Avatar
the oil pan is a big deal in rwd swaps. sometimes you can just cut the pan and shorten the sump if your not hanging up that much on the crossmember. this is what i tried to do for my porsche swap, in the end i just built a custom oil pan.
the pan ended up being so shallow at the front that i had to change the pickup completely. i used a milodon external pickup for a big block chrysler. the front of the pan flange is tapped to 1/2" pipe where it lines up with the oil pickup on the front cover, and i ran a -12 an line between.
Old 08-14-2017, 09:09 AM
F**k it i modified the cross member
Old 08-14-2017, 02:55 PM
Sharkey's Avatar
uhh, what about the massive change in steering geometry thats going to cause? and ground clearance?
Old 08-14-2017, 04:06 PM
Ground clearance shouldn't be a problem and steering geometry the only thing that changed was it made my tie rods more of a straight line with the knuckles and it made the tire toe in a little bit which can be fixed by screwing the outer tierods in a little and steering shaft will be modified also because im transplanting the cobalt steering wheel into the 240
Old 08-14-2017, 04:27 PM
hawkssoccer11's Avatar
i cant wait to see this thing when its done!!!
Old 08-14-2017, 04:37 PM
**** I can't wait to drive this Beast
Old 08-14-2017, 11:16 PM
Sharkey's Avatar
what about bump steer? anytime you move the steering rack up or down you start to induce bump steer. your suspension moves in an arc, and the tie rod has to move in the same arc as the control arm. when these arcs arent the same you get toe changes (bump steer) through suspension travel. being just slightly off will cause the front end to feel unstable in a corner, being way off will cause the car to change lanes over bumps, it can be downright dangerous. on my 944 i dropped the subframe 3/8" for bellhousing clearance and i can feel the bumpsteer, but its still driveable.
its hard to tell from the pics, how far did you drop the subframe? it looks like 2 1/2" to 3". the down and dirty theory is assuming the car had little to no bumpsteer to begin with, whatever you lowered the track you need to lower the steering arm. normally small corrections can be done with bump steer kits that lower the tie rod end, but your not going to correct that much of a change with a bump steer kit. bump steer kits are also bad for flexing, and dropping the steering arm down that much using a bump steer kit would be a failure waiting to happen.
i would highly recommend that before you proceed to put a wheel on it and measure off a fixed point on the car and cycle the suspension up and down with a floor jack and see how much the toe changes.
Old 08-14-2017, 11:27 PM
  #36
Ok sharkey i will check it tomorrow honestly didnt think about bumpsteer should i fix the toe in it has already got from me lowering the rack before i check it
Old 08-15-2017, 12:01 AM
  #37
Yeah more i think about it your right sharkey i fucked my self on that one. Ain't nothing a welder cant fix looks like im putting it back where it was and looking it doing the oil pan i really didn't want to do the oil pan but i guess its trial and error when it comes to dropping a motor in a car that its not supposed to be in
Old 08-15-2017, 01:38 AM
  #38
Sharkey's Avatar
you can zero the toe before checking it, that would be the most accurate way to measure the bumpsteer. i do think the best thing to do is put it back the way it was and mod the oil pan.
the 2.2/2.4l pan is a little different than lnf/ldk pan, its more of a front sump design. it has some ribbing between the sump and the rear, but that could be trimmed away. this may work better for you being the 240 had a front sump pan. maybe that and some notching of the crossmember is the answer. here is a pic of a 2.2 pan
Old 08-18-2017, 09:04 PM
  #39
Ok fixed the crossmember and started the oil pan
Old 08-18-2017, 10:03 PM
  #40
Sharkey's Avatar
that looks great, should have lots of oil volume.
yesterday i ran across a miata swap pan, it may have worked for you, but the $800 price tag is rediculous
Old 08-18-2017, 11:24 PM
  #41
Yeah sharkey i seen those and was like **** that ill make one lol but thanks for the advice on the k-member that could of been bad
Old 08-18-2017, 11:52 PM
  #42
Sharkey's Avatar
he no worries, i try and help where i can. ive fixed a number of cars with major bump steer problems, and built a couple of road race cars. this past week i put the rack in another street legal road race car my shop is building. there is far more geometry to look at than one would think in order to get the correct bump steer (which is 0) and proper ackerman.
Old 09-03-2017, 05:32 PM
  #43
A little Progress and mocking up
Picked up a bumper and pop up lights
Spool gun not tig
Looks so sweet in the 240
Sits alot lower now
Mocking up the dash with the cobalt steering wheel and electric power steering
Old 09-07-2017, 11:04 AM
  #44
Custom bow tie motor mount brackets
I decided to fab a chevy emblem bracket for my tube to be welded to for the motor mounts they will be bolted and put a small weld to the chassis
Old 09-12-2017, 07:15 PM
  #45
Plugged the holes in the firewall
Old 09-12-2017, 07:16 PM
  #46
i love this thread. nice stuff
Old 09-12-2017, 07:21 PM
  #47
Thanks bro
Old 09-12-2017, 07:44 PM
  #48
Test fitting with the new motor mounts
Old 09-13-2017, 09:54 AM
  #49
royce777's Avatar
very nice! you gonna shave some more stuff in the bay?
Old 09-13-2017, 10:51 AM
  #50
Thanks and yes im shaving the whole bay what ever bolt hole or blank hole that isnt being used is going to be plugged and shaved i still have to do the passenger side i did the driver already
Quick Reply: Ecotec 2.0 LDK swapping into a 240SX S13
