Ecotec 2.0 LDK swapping into a 240SX S13
#54
So i decided to run exhaust thru the hood i think i might have the only hood exit exhaust with a baby ko4 turbo lol but its just temporary once i get it running and work out all the kinks i will be pulling everything back out to build the motor and paint and of course a big boy turbo and custom manifold and exhaust
#58
Yeah i know right lol i figured since I got rear-ended the motor had to go in something rear wheel drive it was either going to be a Miata or 240 it had to be something light and rear wheel drive I did a lot of research and couldn't find anybody that's done this swap yet so I figured what the hell I'll do it every time you look up 240 SS it comes up a ls swapped 240 and those are a dime a dozen my 240SS will be one of a kind...well i guess until it catches on and others do it but im not going to lye its been alot alot of fab work to make it work so far lol
#62
In for updates, thinking about doing something similar for our 240 but I don't want to use the turbo application. That oil pan is the only thing that scares me. I can't weld so fabricating that would not be easy. Do you mind letting me know the measurement between the back of your oil pan and where your sump starts? That would let me know if I at least have the option of ponying up for the miata pan.
#63
#65
Droptoppaul the sump starts 12" from the back of the block and the sump is 10.5" so the oil pan is 22.5 long overall sump is 3.5" x 10.5" x 14" can hold 8qt no problem it also has trap doors to hold the oil near the pick up. Hope that helps but i agree with the guys if your going to do something like this u might want to make it worth it and boost it one way or another i vote turbo tho lol and fyi its alot of fab work and im only half way thru it
#66
For the record, the Miata pan will clear easily. The Miata pan is 15" from the rear of the pan so we'd have 3" of clearance over the 240 subframe apparently. Quite intriguing! I may have to start this project!
#67
The miata pan should work no problem i would have went that route but i didnt want to pony up 700bucks for something i could make. You should do it and start a thread if u do decide to do it
#75
Yeah me too lol i just wanted to keep the electric power steering and not have anything else running off the crank pulley besides the alternator
