Ecotec 2.0 LDK swapping into a 240SX S13 - Page 3 - Cobalt SS Network
Go Back  Cobalt SS Network > Engine Technical Discussion > ADVANCED Performance Modifications
Ecotec 2.0 LDK swapping into a 240SX S13 >
Old 10-21-2017, 08:57 AM
  #51
BurnNrubberSS is offline
Old 10-21-2017, 09:01 AM
  #52
Old 10-21-2017, 09:04 AM
  #53
Old 10-21-2017, 09:08 AM
  #54
So i decided to run exhaust thru the hood i think i might have the only hood exit exhaust with a baby ko4 turbo lol but its just temporary once i get it running and work out all the kinks i will be pulling everything back out to build the motor and paint and of course a big boy turbo and custom manifold and exhaust
Old 10-22-2017, 06:54 AM
  #55
Coming along nicely!
63 Nova SS is offline
Old 10-22-2017, 12:38 PM
  #56
Thanks man i wish i didnt have to work this thing would already be on the road lol
Old 10-22-2017, 08:21 PM
  #57
Dart_SI's Avatar
About time somebody pulled the trigger on this idea.
Dart_SI is offline
Old 10-22-2017, 08:36 PM
  #58
Yeah i know right lol i figured since I got rear-ended the motor had to go in something rear wheel drive it was either going to be a Miata or 240 it had to be something light and rear wheel drive I did a lot of research and couldn't find anybody that's done this swap yet so I figured what the hell I'll do it every time you look up 240 SS it comes up a ls swapped 240 and those are a dime a dozen my 240SS will be one of a kind...well i guess until it catches on and others do it but im not going to lye its been alot alot of fab work to make it work so far lol
Old 10-22-2017, 09:45 PM
  #59
nice!
07MetallicSC is offline
Old 10-23-2017, 08:29 AM
  #60
royce777's Avatar
keep up the good work!
royce777 is offline
Old 10-24-2017, 04:35 PM
  #61
Nice!
Viperoni is offline
Old 10-25-2017, 04:04 PM
  #62
In for updates, thinking about doing something similar for our 240 but I don't want to use the turbo application. That oil pan is the only thing that scares me. I can't weld so fabricating that would not be easy. Do you mind letting me know the measurement between the back of your oil pan and where your sump starts? That would let me know if I at least have the option of ponying up for the miata pan.
droptoppaul is offline
Old 10-25-2017, 04:39 PM
  #63
If you're still in the Denver area and plan on this please send me a PM I'll gladly lend a hand and can help with getting the tuning dialed in. But you should def use a turbo unless you're planning on a TVS1320 on a LE5
ECaulk is offline
Old 10-25-2017, 04:46 PM
  #64
AHelm3's Avatar
Not sure how I'm just seeing this thread. Awesome to see more of these being swapped into RWD applications.
AHelm3 is offline
Old 10-25-2017, 06:25 PM
  #65
Droptoppaul the sump starts 12" from the back of the block and the sump is 10.5" so the oil pan is 22.5 long overall sump is 3.5" x 10.5" x 14" can hold 8qt no problem it also has trap doors to hold the oil near the pick up. Hope that helps but i agree with the guys if your going to do something like this u might want to make it worth it and boost it one way or another i vote turbo tho lol and fyi its alot of fab work and im only half way thru it
Old 10-27-2017, 12:04 PM
  #66
Eh...I do endurance racing. Boost is kind of the devil for endurance. Just end up fighting heat the whole time. I'd use it in WRL or Chump car where the goal is purely to finish.
For the record, the Miata pan will clear easily. The Miata pan is 15" from the rear of the pan so we'd have 3" of clearance over the 240 subframe apparently. Quite intriguing! I may have to start this project!
Old 10-27-2017, 12:52 PM
  #67
The miata pan should work no problem i would have went that route but i didnt want to pony up 700bucks for something i could make. You should do it and start a thread if u do decide to do it
Old 11-12-2017, 10:19 AM
  #68
lil work done charge pipes,intercooler and started mock up on lights and radiator
Old 11-12-2017, 10:30 AM
  #69
Since the Nissan p/s pump uses a V belt and the ecotec uses serpentine, what's your plan for making power steering work?
Old 11-12-2017, 10:39 AM
  #70
Droptoppaul i am using the cobalt ss steering wheel because it has electric power steering i have to cut and extend the shaft to make it work
Old 11-15-2017, 10:15 PM
  #71
Mocked up the 7" led light bars for my headlights and damn they are bright asf and they look awesome
Old 11-16-2017, 11:08 AM
  #72
advise's Avatar
looks good man coming along nicely
fab work looks on point too
Do you weld for a living ?
advise is offline
Old 11-16-2017, 11:33 AM
  #73
Thanks man and yes i weld fab and weld daily we build aluminum flat beds for spray trucks
Old 11-16-2017, 11:34 AM
  #74
Nice progress, definitely a fan of the Chevy wheel in the Nissan
ECaulk is offline
Old 11-16-2017, 11:42 AM
  #75
Yeah me too lol i just wanted to keep the electric power steering and not have anything else running off the crank pulley besides the alternator
Quick Reply: Ecotec 2.0 LDK swapping into a 240SX S13
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
