HARROP TVS, What You Need To Know & FAQ
Old 01-21-2010, 07:45 PM
  #126
RooTBeeR's Avatar
its really easy actually, not complex...its just like taking off the m62 but u also need to modify the map sensor a little bit
https://www.cobaltss.net/forums/show...00&postcount=5
Old 01-21-2010, 09:13 PM
  #127
06_SIC_SS's Avatar
Originally Posted by Billig ss/sc
Actually right after I posted that, I read your sig and a "oh duh" moment happened. I'm debating whether or not I should just drop right into the 2.9" when I get the TVS. ...if I get it that is haha
And dude come back into the ***** threads, we miss ya
i jumped right to the 2.9 and 60s.. ull be fine without meth
Old 01-22-2010, 12:14 AM
  #128
jonnymerk's Avatar
Originally Posted by ~Mike~
of course I kid....but how did you know you were goin that fast considering our speedo's only go to 160? lol
GPS? If not thats usually how most do it
Old 01-22-2010, 03:15 PM
  #129
Billig ss/sc's Avatar
Sweet. I can't wait.
Old 01-22-2010, 05:19 PM
  #130
jazzyjames1371's Avatar
cant really see how to modify the map in that pic. was hoping some one had a before and after pic of the map sensor and the mounting spot. well im not a complete retard so hopefully i can just figure it out in late feb when i put my tvs on.
Old 01-22-2010, 06:21 PM
  #131
RooTBeeR's Avatar
pop ur hood, look at urs, and compare it to this one
i actually didnt have to cut as much away, but i did end up redrilling a whole for the screw its should be pretty east to see what was cut away
Old 01-25-2010, 11:09 AM
  #132
^^All you're really modifying is the piece that holds it to the car right? Just makin a little cut in the plastic?
Old 01-25-2010, 11:15 AM
  #133
Brenticus's Avatar
Sub'd
Old 01-25-2010, 09:33 PM
  #134
RooTBeeR's Avatar
yes, just around the bolt hole
Old 01-25-2010, 09:38 PM
  #135
Sizzle06's Avatar
I trimmed mine and just let the tvs hold it down.
Old 01-25-2010, 10:37 PM
  #136
RooTBeeR's Avatar
yeah, i kept the bolt in mine cuz im puttin a supercharger spacer in there...eventually
Old 01-27-2010, 08:13 PM
  #137
thats so much better. here i was thinking i had to grind down the intake manifold to make the map fit differently. thanks rootbeer.
Old 02-04-2010, 04:57 PM
  #138
Do you guys think the GMPP Sport (with Vibrant header/dp) exhaust flows enough or do I need a 3" exhaust? The TVS will have a 2.9 on it too
Old 02-04-2010, 07:18 PM
  #139
383_Stroker's Avatar
My car with a shorty header... 2.5 dp and gmpp touring, makes about 20.5psi on the 3.1".. made 304hp/276 tq
3" would be better.. but it's not going to KILL it..
Old 02-04-2010, 11:34 PM
  #140
InfraRedline's Avatar
Originally Posted by 383_Stroker
My car with a shorty header... 2.5 dp and gmpp touring, makes about 20.5psi on the 3.1".. made 304hp/272 tq
I thought your cutout was open when you dyno'd that, wasnt it?
Old 02-05-2010, 12:45 PM
  #141
Valid Point
Had i completed my thought, i would have finished the story which was that the same day, it ran exactly even up to 120-130 with a TC that dynoed 308hp .. with the cut-out closed... so, it wasn't hurting it much to be capped up..
Pretty sure i wasn't intoxicated when i posted the first one.. but i left out 3/4 of what i was gonna post
Old 02-05-2010, 12:58 PM
  #142
Pyros777's Avatar
I ran the 80mm on the 100% stock exhaust for a while. That setup pushed an uncomfortably high 21.3psi @ about 40F ambient. Don't know what my EGTs looked like at that point, but it felt fine. I'm sure it would be a bad idea to run it like that for too long though.
Old 02-05-2010, 01:30 PM
  #143
Valid Point
Lol you crazy bastartd spreadin misinformation and what not
Old 02-05-2010, 06:47 PM
  #144
lol.. almost never on purpose...
Old 02-06-2010, 12:12 AM
  #145
RooTBeeR's Avatar
...also add to the first post
is it harder to change the oil filter with the tvs than the m62?
yes, its retarded hard...need small hands and drip oil on things haha
Old 02-06-2010, 04:16 PM
  #146
Tennpenn83's Avatar
it's actually quite easy if you unbolt the ambient air temp sensor, and bolt it back in 180* turned around.
Old 02-14-2010, 10:04 PM
  #147
SSLOW06's Avatar
As far as a header goes for use with a TVS would the slp header be good ? The primaries are 1 5/8 . it will be to a 3in catless downpipe 2.5 catback. But i will also have a cut out. I have dual pass option b and also the progressive ais system. ls4 tb 3in zzp intake.
Old 02-15-2010, 04:54 PM
  #148
WickedSS2005's Avatar
That'll do pig, that'll do..
Old 02-15-2010, 05:00 PM
  #149
SSLOW06's Avatar
Pig ??????? Whats that all about ?
Old 02-15-2010, 05:30 PM
  #150
Ever see the movie Babe?
Quick Reply: HARROP TVS, What You Need To Know & FAQ
