How do you seal a tb adapter LSJ?
Old Mar 14, 2012 | 12:29 PM
Cam g's Avatar
I have an adapter for a throttle body with meth/nitrous inlets from zzp.. The gasket for our tb is actually a seal.. The tb or intake tube has to have a slit for this gasket.. So how if I put in this adapter will I seal it being that it didnt come with gaskets and the adapter is perfectly smooth so the stock seal will not work?
Old Jul 5, 2012 | 11:51 PM
wayfarer's Avatar
I have the same adapter, and wondered the same thing.
The stock seal is in the blower, the stock throttle body is smooth, and there's no reciever groove in the spacer for another seal, so it's sealed between the blower and the spacer, but not between the spacer and the throttle body.
I emailed zzp, the response was something like "it shouldn't leak, but if it does, you can use a bit of silicone"
Old Jul 5, 2012 | 11:54 PM
overboostedss's Avatar
Black or grey rtv silicone will work fine. Just lay a goob bead so it fills properly
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Trav3480
Sep 28, 2015 02:46 PM
Sep 28, 2015 12:51 PM
