LIPSTICK's 800hp first LNF compound turbo/engine build!
#427
thanks for the confirmation!
Talked to cmiller who has the "5th injector kit". He told me that the injector flows 60lb/min.
And this 60 lb/min "5th injector kit" + zzp stage 1 cams w/ big fuel lobe....has been powering zzp cars and customers that has 500-600whp+++ cars with Ethanol.
so, I'm hoping/assuming that my zzp s1 cams w/ big fuel lobe + 168 lb/min port injectors (4 x 42lb/min)......will be able to power 700whp using ethanol?
we'll see what happens. If it still lacks fueling....I'll upgrade to 4 x 62lb/min injectors or bigger
#428
So thats millers secret? A 5th injector kit? A bigger turbo? Why keep a simple idea kike that secret? Also, Matt can you chime in. So the 5th injector, does it evenly spread for all intake runners? Where is the location and has this been the idea powering your big turbo stuff? What controls the 5th injector?
#429
https://www.cobaltss.net/forums/2-0l...jector-269859/
#430
I think you're talking about miller (sky forum).
I'm talking about cmiller here who has a cobalt
he has a thread about his 5th injector kit....so no secrets there!
#431
#434
SMG finally finished installing the engine/drivertain/etc back to my car.
LIPSTICK was towed out from SMG this morning.
LIPSTICK was delivered at joshmass aka project scarab's BRAND SPANKING NEW SHOP.... by noon.
we'll just wait for Baldturbofreak (BTF) to arrive in a couple of hours (fron upstate NY)...........here in MA/RI. He'll personally install the compound turbo kit this afternoon/weekend at project scarab's shop. And tune it.
I'm hoping that we can start the engine this Sunday.
#437
tell me about it bro.
Its really tough to deal with several shops/vendors with a build. I'll never do it again.
Next time, it will only be one shop.
Too much aggravation....and time delay.
Anywho, I'm glad that baldturbofreak will finally personally install and tune the compound turbo kit this weekend. If there are tons of bugs to fix..........I'll just have him bring the car back to upstate NY, so he can work on things.
#440
amazing build thread.
seriously dropped my jaw several times.
took me forever to read through it all, but I learned quite a bit.
Looking forward to you finishing this, Antonio.
Thanks for the info on forgestar as well!
#442
Not much happened today due to us finding out that the car will be FEATURED in a Magazine!
I'll keep the name of the magazine anonymous though, sorry.
so BTF decided to polish the raw stainless steel pipings of the compound kit the whole day today.......so they will look purdy for the camera.
The official camera guy of the magazine came in the afternoon to take some photos of the build.
So basically today.........other things that have been done were relocating of wirings, power steering, etc.......
An hour ago, BTF started assembling the compound kit.
Tomorrow install of the kit will begin.
anyways here are some photos:
Exhaust Manifold
hot pipe from small turbo to big turbo that has the flange for the 60mm wg and 38mm wg
4" downpipe
GT4294r and GT2871r turbos
BTF started assembling the kit
Exhaust Manifold connected to gt2871r with the 60mm wg
gt4294r plugged to the kit
installing the big turbo..........and the cold pipe that attaches the big compressor output to the small compressor input
Kit is fully assembled by BTF:
different angles of the compound turbo kit
Exhaust Manifold
4" downpipe
#446
BTF is bolting up the exhaust manifold.
small turbo was bolted
Big turbo was bolted
60mm wg was bolted
cold pipe between the two turbos
brackets were made to make sure that the manifold will not be stressed out with weight of the kit:
Compound turbo kit and WERKS Race Intake Manifold installed!!!
BTF will tow my car back to his dyno/fab shop in Upstate NY......to fix all the bugs......and dyno tune the car.
So I'm hoping I can drive the car end of July 2012!
The kit will be removed so they can be sent to Swaintech for coating....then tuning begins!
60mm wg was bolted
