LIPSTICK's 800hp first LNF compound turbo/engine build!
Old 07-01-2012, 06:38 PM
  #451
Wert842's Avatar
This thing looks like its gonna be a monster. I want one for my coby!
Old 07-01-2012, 06:51 PM
  #452
TWM Performance's Avatar
This build is awesome!!
Old 07-01-2012, 06:52 PM
  #453
40rty's Avatar
This will definitely be top Kappa in engineering and Power.
Old 07-02-2012, 02:33 AM
  #454
Fastgti69's Avatar
This setup is unreal. compounding an LNF you guys have *****. This car is easily 1000whp capable. SICK!
Old 07-02-2012, 02:34 PM
  #455
SKY888's Avatar
LIPSTICK is all strapped-up heading to BTF Racing for completion and dyno-tuning.
photo taken by Median Magazine
pls like MEDIAN MAGAZINE on Facebook! Welcome to Facebook - Log In, Sign Up or Learn More
Thanks!
Old 07-02-2012, 02:39 PM
  #456
when do you plan to have numbers?
Old 07-02-2012, 02:51 PM
  #457
ei3dag3's Avatar
looks like its time for a wire tuck
amazing progress.
Old 07-02-2012, 04:58 PM
  #458
cmiller8006's Avatar
Looking good.
Old 07-02-2012, 05:03 PM
  #459
ford's Avatar
I would like to see 700hp out of this build but i have my reservations. Good luck man!
Old 07-02-2012, 08:06 PM
  #460
SKY888's Avatar
we are hoping by end of July 2012.
but we'll se.....
what's your reservations bro?
Old 07-02-2012, 10:36 PM
  #461
Matt M's Avatar
He's just saying that you have a huge challenge ahead of you getting it all to work right. ...but that's the fun part, right?
Old 07-02-2012, 11:02 PM
  #462
One thing. Won't once the gt42 gets flowing the gt28 become a hinderence since thats like a 3 inch compressor outlet and the 28 is like a 2 inch or so. I have been thinking about this for awhile now.
Old 07-03-2012, 06:23 AM
  #463
SKY888's Avatar
got it!
it's been a huge challenge since the beginning, actually.
so I guess, I'm immuned now with the upcoming headaches
Old 07-03-2012, 06:27 AM
  #464
SKY888's Avatar
yeah, the 3" piping will taper off to 2.25"
the small turbo will not be a hindrance.
that's always one the first questions of most people about the compound set-up.
i think we discussed about this during the first few pages of this thread already.
The small turbo is being forced-fed with already compressed air from big turbo
Old 07-03-2012, 07:58 AM
  #465
cubaniche's Avatar
Hey Sky, you mind if I ask an off topic question?
You mind sharing the specs of those bolts you used for the VC? I need to replace mine and Im having trouble finding the correct spec and I dont want to pay the dealer 5 bucks a bolt
You can PM me if you'd like.
Old 07-03-2012, 08:03 AM
  #466
SKY888's Avatar
VC?
v-band clamps?
Old 07-03-2012, 08:11 AM
  #467
cubaniche's Avatar
VC?
v-band clamps?
ValveCover
Old 07-03-2012, 08:31 AM
  #468
SKY888's Avatar
valve cover....duh!
bro, I believe SMG used just the stock bolts for the stock cover. Fred is out for a week for a vacation. I'll try to ask him when he comes back
Old 07-03-2012, 09:16 AM
  #469
Matt M's Avatar
When setting up a turbo or turbos, whatever size is enough, will always be enough, unless you change the VE of the motor. As you add a second stage, you are just turbocharging the system that was already there. In other words, if the GT28 works well on the 2.0, then adding another turbo system on the outside of the system that is already there won't change that. Your example would be like asking if you need to replace your throttle body with a larger one when adding a turbo. Of course the answer is no, because the air flowing through the throttle body will be compressed and therefore it's flow potential is increased.
Try to think of compound turbocharging as taking an engine that is already turbocharged and then simply turbocharging what was already there. The larger turbo is completely on the outside of the system that was already in place for this reason. That's why you don't need to change what is already there.
Old 07-05-2012, 02:34 PM
  #470
Terminator2's Avatar
but we'll se.....
One thing I would worry about is to make sure the MAF is in a big piece of pipe because if it sees much over 11500 hz the ECM tends to get pissed and it responds by slamming the throttle shut.
Old 07-05-2012, 05:10 PM
  #471
Matt M's Avatar
It does? Is that a Kappa specific issue? We have never had that problem on LNF Cobalts.
Old 07-05-2012, 06:42 PM
  #472
Omiotek's Avatar
yep the kappas dont like the bigger intakes but it can be worked with.
Old 07-05-2012, 07:54 PM
  #473
40rty's Avatar
If you ventured more into the Kappa world you would know this, lol. You guys set records with FWD Cobalts, right? Imagine the times a Kappa(RWD LNF) could do! I'm seriously surprised you guys haven't bothered with much besides downpipes and other things.
Old 07-05-2012, 09:36 PM
  #474
Matt M's Avatar
lol, we only have so much time in a day, and so many days. We do what we can.
Old 07-06-2012, 02:49 AM
  #475
Omiotek's Avatar
this but yes its an issue. cobalts came with a lot more to work with then the kappas.
Quick Reply: LIPSTICK's 800hp first LNF compound turbo/engine build!
