LIPSTICK's 800hp first LNF compound turbo/engine build!
Old 10-06-2012, 03:50 PM
  #501
40rty's Avatar
Well that would fall short as well since his build is for 800hp
Old 10-06-2012, 04:14 PM
  #502
theamericanautos's Avatar
great build! subd
Old 10-07-2012, 11:43 AM
  #503
mkriebs's Avatar
Run the 255 in the tank and the 400 inline, if you can.
Old 10-16-2012, 09:49 AM
  #504
Blinker fluid's Avatar
holy ****.
Old 11-15-2012, 08:58 PM
  #505
SKY888's Avatar
Update:
BTF is still working on fabbing the secondary fuel tank that will be placed inside the trunk.
We are hoping that everything will be finished by the week-end after Thanksgiving.
Then tuning begins....
for the past few months, wife and I have been very busy moving into the new house and unpacking. Also been attending pregnancy/baby classes.
Also working with Median Magazine to feature my car. They ended up having a 5-page spread article for LIPSTICK.
I'm hoping that the car will be on the cover of Median Magazine once the build is finally finished, and have another feature that will include more about the build, fabrication, tuning, dyno and etc.
MEDIAN MAGAZINE will be the best source for local high performance automotive news in the Northeast Region of America. All the top shops. The big builds. Products and services from local companies. Tech articles. It's all gonna be there.
check out the facebook account: http://www.facebook.com/mobileprotec...ianMag?fref=ts
sorry for the blurry photos of the pages of Lipstick:
Old 11-15-2012, 09:02 PM
  #506
RandyO's Avatar
I think I just pooped a little bit. lol
Old 11-15-2012, 09:22 PM
  #507
Matt M's Avatar
That's a great write-up! Good work.
Old 11-15-2012, 09:35 PM
  #508
SKY888's Avatar
Matt, did you read that the ZZP stage 1 cams were mentioned on the article?
Old 11-15-2012, 09:47 PM
  #509
Matt M's Avatar
I see that. Thanks for the plug!
Old 11-15-2012, 11:45 PM
  #510
Stamina's Avatar
The article is well-written and well-researched, for instance, about the WWII aircraft. Many don't know about how those planes pioneered some of the water/meth injection, two stage turbo/supercharging, nitrous, etc. technologies/improvements back then. The guy writing this is obviously an educated guy.
I noticed they mentioned cams twice in the parts list breakdown. I realize that the ZZP Stage 1 cams are a fueling mod, but putting "LNF camshaft" on the engine list also is inaccurate. Though the Stage 1 cams are a fueling mod, they aren't straight LNF cams either. He also made it singular. Are you running the LNF camshaft on the exhaust side and the ZZP Stage 1 on the intake side or something?
Old 11-15-2012, 11:53 PM
  #511
Omnigear's Avatar
emaild supah street on your build and modified mag
^_^
Old 11-16-2012, 06:32 AM
  #512
06blackg85ss's Avatar
bad ass.
Old 11-16-2012, 07:18 AM
  #513
SKY888's Avatar
its actually my mistake. When they asked me for a mod list....I sent them that.
it supposed to be LNF crankshaft
Old 11-16-2012, 07:19 AM
  #514
SKY888's Avatar
article written by my compound builder (BTF)
the editor/owner of the magazine.......asked BTF to do an article for this build
Old 12-01-2012, 02:42 PM
  #515
SKY888's Avatar
Liquid Black powdercoat for the charge pipes and turbo compressors
Old 12-01-2012, 05:35 PM
  #516
40rty's Avatar
Antonio how is the tuning?
Old 12-01-2012, 07:35 PM
  #517
SKY888's Avatar
BTF is still working on the fabbing of the secondary fuel cell.
no tuning yet, unfortunately
Old 12-01-2012, 07:47 PM
  #518
RooTBeeR's Avatar
when finished, will be so epic.
hope they keep moving it along at least
Old 12-08-2012, 06:42 PM
  #519
Knightwolf's Avatar
Subb'in this ****
Old 12-10-2012, 08:54 PM
  #520
BoostedEco's Avatar
subbed... awesome build!
Old 12-10-2012, 09:36 PM
  #521
TX.SS.TC's Avatar
Subd
Old 12-10-2012, 09:50 PM
  #522
klutch814's Avatar
subd lol
Old 02-19-2013, 10:36 AM
  #523
jittjoey's Avatar
Any updates
Old 02-20-2013, 01:40 AM
  #524
40rty's Avatar
Last time Antonio shared with us that the car would be done but its not a priority due to a new addition to the family. Lipstick will start being tuned come summer.
Old 05-20-2013, 09:24 PM
  #525
SKY888's Avatar
sorry for being out for a long time.
Lots of life changing event. Built a house and had a baby last Dec 7, 2012.
My baby Sufina Bree is about 5.5 months.
She occupies most of my time lately.
also been busy with other forums about home improvement, as well as with my new car a 2012 Nissan Leaf
Been on other forums pertaining to Solar Panels, since Im planning to install a 7.2kw system soon.
that's why finances towards the compound build has been at the back burner.
I communicated to BTF lately since I may have some money again....so he can start working on it again....lol
Here are some updates:
Last month, he actually started the engine. He revved the throttle, the motor rocked over and snapped the nipple of the canister valve since its so close to the ABS. so that needs to be worked on.
He also discovered that due to the system size, that the custom end tank of the radiator needs to be modified due to fitting issues. This will be a dual pass radiator system.
He also found out that the drainback slope issue to be solve with the primary turbo being too low and up front.
And lastly having to go around with lots of hot stuff of the compound set-up that needs to be managed in order not to melt important wires/hoses/etc.
custom intake manifold w/ port injectors installed.....with custom 3" intake pipe
also using a 2.4 throttle body
Vibrant Quick release boost braces will be welded on the pipes @ intercooler and TB/compressor.
these will keep couplers from popping off at high boost pressures. Every 10 psi of boost = 80lbs of pull force on 3" pipe. We are planning to go around 45-60psi
we need to really think about all these kind of stuff with this kind of build. Every lil aspect will make it last longer
Quick Reply: LIPSTICK's 800hp first LNF compound turbo/engine build!
