LIPSTICK's 800hp first LNF compound turbo/engine build!
#751
Today, I professionally detailed Lipstick inside and out!
Well this morning was my first time to drive her around the city and highway to get used to with the new power. I'm sory no videos since I don't have a gopro. I wana do it with my phone but it will not be safe.
All I can say is, even with the low boost setting (37psi), it as so worth the wait! Instant spool by 2800 rpm and full boost by 4500rpm! The sound of the engine and the look of the car are such an attention *****!
I can't wait to ty the high boost setting (45psi)
SKY888 (09-20-2016)
SKY888 (09-20-2016)
63 Nova SS (09-19-2016)
#762
thanks guys.
last year, before my bates block died, with s1 cams, and stock head.....it only made less than 500whp at 35psi on the mustang dyno. The head was lifting and giving us all sorts of trouble so we stopped dyno
This year, we upgraded to a zzp girdled block, s2 cams, and some headworks, and started boosting above 37psi. I currently have a low boost (37psi) and high boost settings (45psi). But didnt get the chance to go on the dyno.
We are assuming the low boost setting is at least 530whp on mustang dyno
here's the road tuning that BTF made for me.
As you can see the boost is high, BUT the timing is only 7 degrees, AND no signs of any knock whatsover.
It can easily gets way more whp/tq if we bump that timing to 15-20 degrees. We can do that later on, since the power is way more than I can enjoy especially on the streets.
Just want to get comfortable with the power first....then later upgrade for more power. Safety first
#763
Why wouldn't you run more timing at less boost? I made 511 @ 27.3psi
SKY888 (09-20-2016)
#766
I believe the LNF loves timing and makes more whp/tq with it
but remember that with compounds, it loves high boost.
having two turbos, we have to make each of them happy with their respective PRs.
The interactions between the two turbos is the key, or it will run like crap
We played with different PRs of both turbos, and with my current set-up, and this is where both of them are happy.
Trust me it was a very frustrating tuning experience since the set-up is very complicated.
That's why we focused on finding the right PRs first. Then we can just add more aggressive timing later.
car runs perfectly right now, without any hiccups. The transition between the small and big turbo has no hiccup, which is awesome.
Even the injection of methanol by the port injectors is very smooth.
These are the key at the moment, and I love the way she drives and plenty of power in the streets.
We'll add more aggressive tuning later.
#767
the big issue with my current set-up is my oil catch can.
It's collecting some oil during very high boost.
Afraid that the turbos will be sucking oil.
What have you guys done with your OCC set-up?
#772
What fuel are you running? Full methanol on the port side? What in the DI side? How are you controlling boost MBCs?
#773
I'd run the DI on E47 can turn up the spool
#775
