LNF ZZP ported head and cams
Old 05-10-2013, 06:41 AM
Black_Mamba_09's Avatar
Hey guys, I am interested to see who is running ZZPs ported head with cams on an LNF.
Old 05-10-2013, 09:37 PM
rking7's Avatar
I am. Love it.
Old 05-11-2013, 01:25 AM
Whats your set up? Is the car built?
Old 05-12-2013, 01:30 AM
cmiller8006's Avatar
I will be once I put it back together.
Old 05-14-2013, 05:34 AM
I figured you already had that set up cmiller. I building the my motor when I get back from Afghanistan. I am still unsure on what turbo I want. I know we talked about turbos already.
Old 05-14-2013, 07:05 PM
Nope was on stock head, had cams tho.
Old 05-14-2013, 11:43 PM
taintedred07's Avatar
I'm already on e85, bolt ons, stock turbo. Thinking in the long run of things, I think I'm going to swap to their ported head with cams and everything so I can already have that taking care of for a future build.
Old 05-24-2013, 11:46 AM
rking7's Avatar
Not built yet. Fully bolted, stock turbo. The motor has 99,300 miles, and is loving the new top end. I have the rotated front and rear trans mounts running continental dws extremes, and hooking up, nor wheel hop are an issue. I can highly recommend this mod. The only parts on my car the aren't zzp are the Hahn intake, and Hahn cat back exhaust. I threw one code while driving pretty hard for an extended period. It was P2096, and it cleared itself. So, no big deal. Hope this is what you were looking for.
Old 04-01-2014, 08:37 AM
crashher0's Avatar
When is a ported head suggested? From what I have read on the LNF engines its not a huge performance gain. Basically none on the stock turbo but when does it start benefitting on a big turbo set up like a zfr or S25x snail? Im in the process of debating a ported head with cams or just cams for an S256et build.
Old 04-01-2014, 02:54 PM
Just cams
Old 04-02-2014, 09:46 AM
crashher0's Avatar
So if I were shooting for 450-500hp just cams will do fine? When does the head porting really show numbers are we talking 500hp+ beasts?
Old 04-02-2014, 01:43 PM
I'm going to be well over 500+whp and I didn't touch my head
Old 04-02-2014, 05:35 PM
crashher0's Avatar
Awesome great to know!
Old 04-02-2014, 06:33 PM
Hopefully you will get to well over 500 with no head work.
Old 04-04-2017, 07:39 PM
theamericono's Avatar
I am looking for 500 hp in the long rune off my 08 ss
looking to upgrade the head to zzp ported,cammed and tune
i need to go into the motor anyways to replace the water pump,timing chain and headgasket.
would this be the best way to go? I am hoping to upgrade to a bigger turbo soonish. The car was running hot @245 and worried if the head comes off for the headgasket it will need replacement anyways.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
HEATON
10-16-2015 07:21 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: LNF ZZP ported head and cams
