Lower intake port and polish project
Old Sep 19, 2008 | 10:50 AM
  #101
ebristol's Avatar
Originally Posted by -Jayson-
A/F ratio wouldnt change. The computer is told to make a certain A/F ratio, no matter how much air i put into the engine its going to try to maintane that A/F ratio. IATS i will get later tonight hopefully.
Not neccessarly. Your computer is being told what a/f to make from the Maf. The Maf was tuned to read your old setup. Now your IM is flowing more air so the readings from the Maf may not be right for the for the new setup.
Old Sep 19, 2008 | 03:06 PM
  #102
ralliartist's Avatar
yea, uh, you are really wrong about that. Once again I appreciate the effort and the observations that you posted from doing this already, but the car is definitely going to run differently. I would venture to say it's a tad leaner now. Changing something like that will definitely affect the tune on the car. Once you get logs up and what not, it will be nice to see what's going on under the hood.
Old Sep 19, 2008 | 04:37 PM
  #103
freakta's Avatar
could that be where the butt dyn o feels the diff just the car running a bit more lean
Old Sep 19, 2008 | 07:24 PM
  #104
well, we don't know for sure, but I'd say it's more than that. It's probably the car running leaner and the fact that the boost comes on quicker also. Probably added more tq than hp though with getting the boost to hit quicker. But that's still a good thing.
Old Sep 19, 2008 | 08:00 PM
  #105
freakta's Avatar
def a good thing, cant wait to see dyno proof to see where the tq curve ran too
Old Sep 21, 2008 | 01:50 PM
  #106
raptors_67's Avatar
That airflow still has to flow by the MAF, air isn't introduced anywhere else in the system so as long as the MAF table is correct through every cell his fueling will stay the same. Having said that I'm sure Volumetric Efficiency is different which would alter fueling.
Old Sep 23, 2008 | 10:10 AM
  #107
anymore info on this? Logs yet? IAT numbers???
Old Sep 28, 2008 | 10:58 PM
  #108
NGalaxyTimmyo's Avatar
No prob Jayson. You caught me on my only day off and put me to work!
And I think the reason why you didn't feel that big of a boost is probably because we took my car a couple times, and feeling that thing pull, and then back to yours, just doesn't feel as fast ;-)
Old Oct 4, 2008 | 09:05 AM
  #109
-Jayson-'s Avatar
its not like i had to twist your arm to work, you wouldnt stop. But actually i think i was right, something wasnt tight enough and i had a boost leak. I took the system apart the other night, fixed a coolant leak and tightened it all down really tight. Its running good. I think we should race, because i mean we both know your car is just going to blow up
Old Oct 24, 2008 | 08:49 AM
  #110
-Jayson-'s Avatar
Just a little update, im having a weird boost leak problem that i cant figure out really where its coming from, the boost leak only occurs after a little bit of driving, when the engine is cold there is not leak, but once ive been driving for a bit, im only seeing 10 PSI.
On another note, did a little monitoring with HP tuners the other day, was about 65-70F outside. Normal driving i was seeing IAT2s of around 130-140F, at WOT it would sit constantly at 120F.
Old Oct 24, 2008 | 08:58 AM
  #111
invisible's Avatar
I had the same problem with a boost leak but it was my computer knocking boost down booost cause my ic pump wasn't working.
Old Oct 24, 2008 | 09:49 AM
  #112
Whew!!!! Jayson, your iat's are pretty high. That 120 is decent under WOT, but your cruising IAT's are up there.
As for port and polished manifold, honestly, there wasn't much of a gain, if any, to be had. The head is keeping it from doing much. But my single pass part of it, now that works GREAT!
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
