Lsj + mp90 supercharger
#285
Rattlesnake Race Shop
I know.
I had considered that at one time... but I think a proper pump set-up putting the Crankcase into vacuum would do much better.
Did you actually change the port on the back of the valve cover? Or leave it stock? Changing that port is the start of successful crankcase ventilation.
#289
Do you mean the Port for the PCV Valve that's in the stock Intake Mani? I've got mine blocked off now. Threaded it, then had an Allen Head plug put in.
And a pump set-up can be cost effective, but done properly, it probably won't be.
I've got the SAI pump off of my VR6 lying around. It should make a good start pump. Put a catch can of sorts in-between it and the -10an fitting that'll be on my valve cover... then rig a Hobbs Switch to engage the pump at 10psi. Should work out quite well, I think. We'll see. One of the better solutions, imo. Pulling 5-10in/hg of vacuum in the crankcase should benefit the engine quite well.
#292
I think I seperated those sentances correctly.
#294
That's the key problem that needs to be eliminated. Make all the outside provisions you want... that fitting is still too small. Needs at least a -10an fitting put on.
