EXNINJA's kit car build thread
#226
The Amazon welder arrived last week so I finished the welding. I realized I forgot a couple of other things so it took a little time. Everything I ordered arrived on Saturday afternoon so I only had that evening to work. The lighting sucked but I managed. The welder was sufficient for what I needed it to do, just dirty being FCAW rather than gas. It rained later, and I need daylight for paint so primer will be next weekend and paint the following weekend (I don't work on it on Sundays).
#235
You live up to your name, that's for sure
#246
Wow, been a while. I've been doing occasional little stuff. I'm determined to get the frame back down on the chassis this weekend. I've attached the brake line and hard fuel line to the tunnel, and fit the gas tank to the back at the angle I want. I need to do a fit check with the rear body work but the piece is buried so I need to dig it out. I just need to attach the EVAP vent tube to the tunnel and I'm good to go. I'll enlist the help of some neighbors and get it done on friday or saturday night.
#250
Did some more work yesterday. I had the goal of putting in the electrical box, but this happened:
If you look carefully, you'll see the end of the rivnut mandrel stuck in the rivnut. Don't he-man a 10-24 rivnut. Here's how it broke:
I was able to spin it out of the rivnut, but unfortunately it spun into the tube. I was too lazy to go get a left hand drill bit and the normal bit just spun it in. Hopefully it doesn't rattle. I moved on to mounting the seat sliders for the driver's seat:
Eagle eyes will notice the sliders are not perpendicular to the mounting tubes. This was done on purpose. The side clearance for the seat shifts a little outboard as you move the seat forward due to the trans tunnel. My fat seat requires the diagonal motion. This kit was not built for fatso's like me, but still better than the shoulder rubbing I've seen in the goblin videos I think. My replacement mandrel arrived today so I'll put the electrical box in tomorrow night.
