All Cars Café The landing pad for automotive discussions, news, articles, and opinions. A place for the community to kick back and chat about all cars.
EXNINJA's kit car build thread
Old 06-04-2018, 03:40 PM
  #101
Liked 376 Times in 333 Posts
Dont you have a Tahoe? No need to push just pull it with a tow strap
ECaulk is offline
Old 06-10-2018, 07:12 PM
  #102
exninja's Avatar
Liked 177 Times in 157 Posts
I thought that my donor's trans was painted black
exninja is online now
Old 06-10-2018, 08:46 PM
  #103
Liked 269 Times in 254 Posts
Cant wait to see this done. Wasn't there a guy on here from time to time posting about his kit car? Wonder what happened?
63 Nova SS is offline
Old 06-10-2018, 09:24 PM
  #104
exninja's Avatar
Seems like there should be more people posting about DF Goblins. Once in a while someone comes looking for parts but I can't recall anyone posting updates about completing the car.
Old 06-10-2018, 09:33 PM
  #105
Liked 167 Times in 148 Posts
one guy on here had videos of a completed goblin.
Sharkey is offline
Old 06-13-2018, 11:35 AM
  #106
exninja's Avatar
This guy showed up yesterday:
It's from a CTS. The bracket conveniently welds onto the Miata pedal assembly in place of the cable throttle pedal. Now I just need to learn how to weld.
Old 06-13-2018, 11:41 AM
  #107
Drill and tap instead
ECaulk is offline
Old 06-13-2018, 11:55 AM
  #108
exninja's Avatar
There's a few more things to weld so I may as well learn I will eventually need to make seat mounts so I'll do the non-life-threatening stuff first. I do have a friend that is experienced helping me so I don't need to worry about killing myself when the time comes to make big boy stuff.
Old 06-13-2018, 12:21 PM
  #109
Liked 141 Times in 137 Posts
I'd recommend starting with a stick welder. If you can figure out how to do that well wire welding will be easy peasy
jdbaugh1 is offline
Old 06-13-2018, 12:31 PM
  #110
exninja's Avatar
hahahaha my buddy also has a mig setup so I'm just going to use that. I'll take free
Old 06-14-2018, 12:02 AM
  #111
ProfDNS's Avatar
Liked 94 Times in 86 Posts
So if you disappear from the forum, we'll know what happened
Good luck with the welding! That is something I'll never be able to do myself - the fumes alone would kill me.
ProfDNS is offline
The following users liked this post: ProfDNS
exninja (06-14-2018)
Old 06-14-2018, 10:54 AM
  #112
exninja's Avatar
Thinking ahead and mostly to document my ideas, I'm thinking of making a gauge cluster/dash out of a Raspberry Pi and screen not unlike this: https://www.miataturbo.net/megasquir...acedash-92851/
I can use the current Miata dash without too many issues. I'd just have to connect wires to the correct lights and such. However, the Pi dash would be pretty cool. The only issue I see is the speedo, where I'd have to either replace the cable with an electric VSS, then input the signal to a conditioning board, or just use GPS into the Pi directly. I'm thinking the former would give me a good signal to the ECU as well (should be able to adjust the pulses/mile with HPT), but it's also expensive unless I can find a VSS for cheap (they go for about $150). I am assuming most open-source CAN bus dashes for the Pi/Linux just pull vehicle speed from CAN rather than using GPS so I'd have to figure out how to program that. The Miata has a functional oil pressure gauge which I can attach to the LE5 with an adapter so I could keep the fuel and oil pressure gauges, or plug the signal into the Pi or Arduino board (yeah I'm still figuring out how those work) and go to town with my own dash.
Old 06-14-2018, 11:13 AM
  #113
ProfDNS's Avatar
GPS can be accurate, but those modules are pretty expensive even for Raspberry Pi. Your best bet is to have a counter on tire rotation (connected sensor, or wireless).
Edit: I'm talking about possibly using the ODB2 connector, not actually wiring your wheels lol. Just realized how silly I wrote it out initially.
I did see a few instructions online for this type of scenario, you just need a digital screen to feed the info to you.
ProfDNS is offline
Old 06-14-2018, 11:26 AM
  #114
exninja's Avatar
I started looking into something like that on the driveshaft but didn't get very far. Theoretically it could be easier and cheaper depending on the signal coming from it if I can skip the conditioning board (the Miata VSS outputs a sawtooth vs pulsed). Another thing I may end up doing is just get an Android tablet with GPS built in. It would be pushing the easy button, but it would be cheaper. I wouldn't have the flexibility of doing stuff like adding fuel and oil gauges or whatever else I wanted, but I could always get a second one for doing other stuff
Old 06-14-2018, 11:55 AM
  #115
ProfDNS's Avatar
If you want Google to track your whereabouts all the time sure, but finding a cheap enough tablet that has enough hardware to do the displays without lag, you'd be hard pressed. An ok-ish tablet (7" for pricing sake) would be around $170. Anything cheaper - that I found - are not worth it.
ProfDNS is offline
Old 06-14-2018, 12:04 PM
  #116
Kolt's Avatar
Liked 164 Times in 147 Posts
Buy a second hand android phablet for cheap. I have used digihud app on my old note 5 at work when either speedometers don't work or when I have to drive huge mudder trucks.
Kolt is offline
Old 06-14-2018, 12:14 PM
  #117
exninja's Avatar
I'd prob see if someone's selling an old Nexus 7
Old 06-15-2018, 02:37 PM
  #118
ProfDNS's Avatar
That's probably your best bet.
Amazon Amazon
ProfDNS is offline
Old 06-15-2018, 02:55 PM
  #119
Kolt's Avatar
That would probably work. anything with a quad core should have plenty of power to give fast updating and maybe even record if you find the right app
Kolt is offline
Old 06-16-2018, 11:21 PM
  #120
exninja's Avatar
Divorced the engine from the trans today. Sure is easy without a car in the way.
Old 06-16-2018, 11:22 PM
  #121
ProfDNS's Avatar
Messy garage is messy.
ProfDNS is offline
Old 06-16-2018, 11:44 PM
  #122
exninja's Avatar
Yup, it's all mil's stuff. Annoying to deal with. At least I have room to work.
And I took the picture before I cleaned up my tools
Old 06-17-2018, 07:22 AM
  #123
Mig welding is really easy, you will master it quickly as long as you get the heat range and feed speed set correctly.
Old 06-17-2018, 10:06 AM
  #124
ProfDNS's Avatar
At least you have a garage. Purchasing a house is not in my financial best interest at the moment - especially since houses "start" at $600k.
ProfDNS is offline
Old 06-17-2018, 10:29 AM
  #125
exninja's Avatar
Housing prices are nuts up there.
Quick Reply: EXNINJA's kit car build thread
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
