Not your typical pick-em-up truck... Ectotec in an '80 Chevy Luv
#51
The problem with junk yards is that they want to give you the motor ONLY for $4-600. If I was just replacing a motor, that would be one thing. But since I'm starting from scratch, it is going to be much easier to start with an entire donor car for $5-700. Still watching a couple Saabs that are going to be coming up on auction, but the insurance companies are taking their good 'ole time.
In the meantime, clean up continues. Going to flip the frame tonight and paint the top side, then set the cab back on.
(Paint looks like ass since its only half dry when I took the pic)
#60
copart can be good and bad. cars can often be misrepresented, and there is little to no recourse. things like no mention of engine damage or non running engines on something that would appear shouldnt have any engine damage, or vehicles getting damaged after the pics were taken. not saying everything on copart is like that, but its something you have to be aware of.
#62
Yeah, there are a lot of negative reviews on Copart, because a lot of people don't really understand how it works lol. I figured if I kept my budget under $500, that even if the car didn't run right, I would still get enough usable parts out of it to make it worth while. This thing actually runs pretty good for 116k miles. Bonus!
#64
Nothing crazy happening yet. I've been selling little bits off the Saab here and there, but haven't really had a chance to tear into it yet.
In the mean time, a bunch of the front suspension parts finally showed up from Japan, and I already had all the other components sandblasted and painted.
Half-ass assembled everything so that I can bolt it to the frame and start cleaning up the garage. There are parts scattered everywhere and its driving me crazy lol.
#65
The Sqaab has been stripped down of everything I plan on selling off of it. Hopefully next weekend I will be able to drop the cradle, and it will be ready to go to scrap.
I've also found a rear end and a trans. Just ned to catch a break from work so I can go snag them at the yards before someone else does.
Rain drop, no top....or doors, or fenders, or headlights, seats, hood...
#68
Opened up the motor last night, and for as grungy as it was on the outside, it is pleasantly clean inside. That got my wheels turning though.
Instead of taking all the time to fab up charge piping to the stock turbo, I might as well just go bigger now. So I have started looking into that.
Also, now that I have the motor out, I've discovered some little issued that will need adressed:
-Deleting the A/C comp, which can be solved by a simple belt swap.
-Blocking off the power steering components at the back of the valve cover.
-I'd like to relocate the oil cooler if possible, as that will allow me some more fire wall clearance.
#70
yea best to just go bigger now and just keep the boost down till your ready to use it all. plus you need to top mount the turbo, just because a top mounted turbo is so much cooler lol.
for the oil cooler your best bet for packaging might be to remove it, pull the tube out of the block and plug the holes, and run a remote filter and cooler using the adapter from CBM motorsports. blocking off the power steering is simple, just get the cover plate from an early l61 cobalt.
good to see some progress
#72
The S200sx won't be here for another 3 weeks. I went ahead and ordered a ZZP Turbo manifold, and a T3 housing So it's ready to slap on when it finally shows up.
In the mean time, I tore off the rest of the accessories and hit the motor with a coat of degreaser.
Also made some templates for the power steering blockoffs.
#74
The smaller one. THM had it on sale for $525, which seemed like a great price, so I jumped on it.
BorgWarner 12709095019: S200SX-E SuperCore Assembly 52.17mm / 2.05" Compressor Inducer Dia. | JEGS
