All Cars Café The landing pad for automotive discussions, news, articles, and opinions. A place for the community to kick back and chat about all cars.
Not your typical pick-em-up truck... Ectotec in an '80 Chevy Luv
Old 11-18-2017, 09:50 PM
  #151
TurboTechRacing's Avatar
Like!
Old 11-20-2017, 07:29 AM
  #152
AHelm3's Avatar
Originally Posted by tomss
Looks tight to the firewall. Also, the way it faces it will be hard to reach the cam sensor and correct the oil leaks that pop up.
Very cool project.
That's not the final location for the engine. I don't even have the cam sensor housing on the back of the head. It's going to come forward to make room for that.
Old 12-18-2017, 11:45 AM
  #153
AHelm3's Avatar
Put the engine back on the stand and "prepped" the engine bay and core support over the weekend.
Old 12-18-2017, 12:20 PM
  #154
jdbaugh1's Avatar
Do you have much fabricating to do yet to mount the engine in there?
Old 12-18-2017, 01:01 PM
  #155
AHelm3's Avatar
Not really. I ordered a set of Solstice engine brackets. I'm hoping those will simplify the engine mounts. The trans crossmember will need modified. Other than that, nothing else should need modified.
Old 12-18-2017, 01:16 PM
  #156
royce777's Avatar
nice to see you still are doing stuff!
Old 01-25-2018, 10:26 AM
  #157
AHelm3's Avatar
Not much going on. Been buying boring stuff.
Picked up an alternator and 80# injectors off of Jeff.
Purchased misc. sensors that I needed to complete the LSJ harness swap.
Finally got the correct rotors so that I could wrap up the front suspension.
Bought tires for the front.
Also bought one of OTTP's remote oil adapters. I had been working on fabricating one, but never had it welded up. They came out with theirs, so I figured I would just bolt that on instead.
07MetallicSC (01-27-2018)
Old 01-30-2018, 11:40 AM
  #158
AHelm3's Avatar
Got the front wheels/tires mounted and the front of the truck is back on the ground. Ball joints probably won't be happy sitting like this, so its final stance will probably be 1-1.5" higher.
Old 01-30-2018, 09:19 PM
  #159
63 Nova SS's Avatar
Sweet! Love the old school wheels. I had fenton slots on my charger a looong time ago, before throwing cragar ss's on.
Old 01-30-2018, 10:52 PM
  #160
Sharkey's Avatar
those wheels do look great on that. too bad you cant keep it at that ride height though. have you looked into drop spindles?
Old 01-30-2018, 11:28 PM
  #161
Henry3959's Avatar
There are so many people that have probably never seen a LUV and will freak out when you hit the road. I was PDI'ing them brand new in 1980.
Old 01-31-2018, 07:22 AM
  #162
AHelm3's Avatar
My old man had them on several of his cars throughout the years. Eventually I'd like to get a brand new set, but that's not a high priority. These were a dirt cheap CL score. I basically picked them up to test width and offset.
No one makes anything for these unfortunately. They drop pretty low just on the stock torsion bars. Unfortunately, if I want to keep it this height, I'll have to hack the control arm/shock mount and raise the mounting points some. Not too big of a deal.
They are non-existent in the north-east. Should turn some heads for sure.
Old 04-02-2018, 04:09 PM
  #163
AHelm3's Avatar
Haven't really messed with this much. I did get a CBMotorsports heater block, and all the -AN fittings to get it ran to the radiator. But now I need a 2.4 coolant crossover, as the factory one from the Saab seems to be longer.
Old 04-02-2018, 06:13 PM
  #164
Sharkey's Avatar
i had looked at the cbm water block thing way back but i thought it was kinda big for what i was doing. i eliminated the crossover pipe and built my own setup. i basically welded a pipe to the back of the water pump cover and welded a remote thermostat housing to it. that setup looks like its gonna work well for your truck though.
what size fittings are those on your oil cooler adapter? maybe its the perspective but they looks kinda of small.
Old 04-03-2018, 07:52 AM
  #165
AHelm3's Avatar
They're -6. The cooler I bought has 1/4" NTP in/out. The plan is to run it inside the frame rail under the drivers side floor board. But I'm also open to other suggestions if this could cause oil starvation/be inefficient.
https://www.summitracing.com/parts/sum-331000
Old 04-03-2018, 12:05 PM
  #166
Sharkey's Avatar
in my opinion thats too small of an oil line, id be worried about oil starvation. -8 would be a minimum, -10 would be better.
Henry3959 (04-03-2018)
Old 04-03-2018, 12:10 PM
  #167
Henry3959's Avatar
True Engine Oil oil coolers generally come with AN-10 fittings for a reason. Your link points to a transmission cooler, not an oil cooler. Get a true engine oil cooler that is non restrictive and take advantage of the large main fittings on that adapter. It looks like they are AN-10
Old 09-25-2018, 04:30 PM
  #168
royce777's Avatar
We want a update
Old 09-25-2018, 04:53 PM
  #169
Kolt's Avatar
I second that.
Old 09-25-2018, 04:54 PM
  #170
royce777's Avatar
He just had a baby so I am sure his time is else where right now
Old 09-25-2018, 04:57 PM
  #171
Kolt's Avatar
Oh yea its def on hold then.
Old 09-25-2018, 05:09 PM
  #172
exninja's Avatar
Originally Posted by royce777
We want a update
Originally Posted by Kolt
I second that.
royce what is you doing?
Old 09-25-2018, 07:52 PM
  #173
63 Nova SS's Avatar
That's really no excuse.
Slowbalt2000 (09-26-2018)
Old 11-12-2018, 10:51 AM
  #174
AHelm3's Avatar
Yeah it's been a crazy summer/fall. My daughter was born at the and of August, followed by a kitchen reno that I am still buttoning up. So needless to say, my free time has been scarce. I did purchase HPTuners, made a bench harness, and downloaded the factory tune. Just need to buy the credits to disable VATS. I also bought a much nicer set of wheels for it. Same style, just much better shape.
Hopefully after the holidays I will be able to take it to my Dad's shop to get some of the heavy stuff done, like fabricating motor mounts, and getting the rear end set into place. The space has been occupied by my brother's S-10 while it was getting a 5.3 swapped in.
The following 2 users liked this post by AHelm3:
Beto2690 (11-03-2020), Kolt (11-18-2022)
Old 11-12-2018, 09:17 PM
  #175
63 Nova SS's Avatar
Congrats!
Quick Reply: Not your typical pick-em-up truck... Ectotec in an '80 Chevy Luv
