Car won't crank please help
Hi I have 2008 pontiac g5 with a 2.2 manual and it won't crank it started off with no engine when key on and my scanner wouldn't connect so I replaced the pcm got the light and I was able to read the codes( 1 code crank position sensor p0315) and after talking to my dad he pointed out the security light and said that it may be why so I got rid of that Still nothing. The guy I got it off of tried to do a cluch bypass on it and the car only has one sensor on the clutch so want I asking if what could cause the no crank I can only think of two things the clutch sensor or crank position sensor
A dealership will need the whole car. Way too many different PCM connectors out there for them to be able to bench tune a PCM.
There are alternatives though. I reprogrammed my own using HPTuners software. Most people that can do that will also need the whole car.
