yea gotta go easy on those small nut-serts, ive broken a mandrel myself.
its looking good. keep it up. |
My experience with rivet nut inserts did not leave me impressed. The worst is when they don't grab enough to keep from spinning but you don't find out until a bolt is all the way threaded in but then you can't remove the bolt because the nut insert just keeps spinning without a good way to grip it with anything. They are handy when they work right though.
Originally Posted by jdbaugh1
(Post 7711136)
(Post 7711136)
also, make sure yous using good nut serts. i avoid the aluminum ones completely. with the steel ones ive got some in bulk before that dont have the spline on the outside to bite into the material to keep them from spinning, and well, they always end up spinning. i have a hard time getting them in bulk where i am anyways, so i usually get the Pop brand (red and white package), and i have the least troubles with them.
ew, yes, i haven't gotten aluminum ones and they've had the splines/knurling.
Like zo:
I played around with a 1/4-20 rivet nut, I riveted one with maximum force and the other was the reduced force setting for the composite material.
https://cimg9.ibsrv.net/gimg/www.cob...8d95e0dae9.jpg |
What installer are you using? My arms aren't well calibrated, but I could back the rivet off to a set distance. I would just need to make sure I have enough thread engagement. As it is, I only squeeze the handles about halfway till the nut bottoms out (on the blind side). When I kept pushing is when i broke the mandrel.
I mostly finished my box and lid last night. I just need to trim a couple of holes in the lid so that I can remove the lid without removing all of the fasteners on one side of the box. I'll take pictures when I do that, the lid alone is pretty boring. |
The setter I used was an air powered unit that threaded into the rivet nut which tightened it against an serrated head which prevented the nut body from rotating and crushed the rivet body that way. Only thing i could adjust was air pressure and I gave it everything my garage compressor could muster. 1 out of 6 spun when I tightened the bolt.
Originally Posted by exninja
(Post 7711242)
I mostly finished my box and lid last night. I just need to trim a couple of holes in the lid so that I can remove the lid without removing all of the fasteners on one side of the box. I'll take pictures when I do that, the lid alone is pretty boring. With this particular tool you can adjust it so that when the handles are fully stroked, it will pull the mandrel inwards a certain distance, deforming the rivnut a certain amount. |
Originally Posted by steelmesh
(Post 7711247)
I got this kit: https://www.amazon.com/Astro-Pneumat...E73MZYBNQ93ACJ
(Post 7711248)
Mine is the Tacklife version of basically the same thing.
https://cimg8.ibsrv.net/gimg/www.cob...d3d2a2b49e.jpg |
As promised, pictures of the completed electrical box. I also connected the rear end to the frame. Next is the front end, then I'll make an exhaust.
https://cimg8.ibsrv.net/gimg/www.cob...e898fe7973.jpg https://cimg1.ibsrv.net/gimg/www.cob...722530ce25.jpg https://cimg0.ibsrv.net/gimg/www.cob...2cee4bda9d.jpg |
Mated the front subframe. I checked clearances and determined for certain I'm doing a side exit exhaust rather than routing the exhaust under the transmission.
https://cimg4.ibsrv.net/gimg/www.cob...b96ff1b594.jpg |
Managed to bolt in the driver's seat with a slider. It's actually quite tricky. Then I let the boys sit in it. They approve.
https://cimg3.ibsrv.net/gimg/www.cob...a0fc5732b6.jpg https://cimg5.ibsrv.net/gimg/www.cob...1f9c0f7156.jpg |
This is so cool, I look forward to seeing more pictures/information as you continue to move forward. :guns:
Are your boys into cars or going fast yet?
(Post 7712083)
Made some progress on the wiring tonight. Got the battery cable onto the starter, and a thick wire from there up to my electrical box. Cut some cable to go between the alternator and starter, but I need to crimp an eyelet onto one end of that. Laid out what I want to do in the electrical box. Reconnected all of the engine harness to see what I need to adjust. Looks like the only wires I need to lengthen are the alternator wires.
https://cimg5.ibsrv.net/gimg/www.cob...df600a6500.jpg https://cimg6.ibsrv.net/gimg/www.cob...2e53e10d8b.jpg |
Looking good, like how everything is getting layed out in the same area and easily accessible. Wish gm would do stuff like that :lol:
Looking good ex!
Originally Posted by Kolt
(Post 7712242)
No problem, that sounds like a nightmare. All that work just to skimp out on wiring.
Took it easy yesterday. Did some shopping and did a "flasher mod." It consists of replacing a resistor in the flasher module so that it doesn't "hyperblink" when you use LEDs. The side effect is that it never hyperblinks, but I'm not worried about that, especially with LEDs.
https://cimg9.ibsrv.net/gimg/www.cob...2f27b65e9c.jpg |
