--||The Official Headlight and Taillight Thread||--
#428
hey guys finally got around to posting a video,
YouTube - my new cobalt RGB LED headlights
These are my new cobalt headlights I designed and built. They are made with custom halos (I made from work), RGB LED strips, RGB LED controller mounted in my car, and repainted gen 2 projectors.
I only show them changing the main three colors but the controller allows for a mixture of all the colors to create new ones (and the legal colors haha)
I will post another video of the other colors. The controller also allows for dimming and shuffling of the colors with varying speeds and brightness.
#435
@Red John, no its an 06 SS/SC G85 package
the only thing missing is the front lip because the previous owner must have removed it
#442
#443
Would it be possible to swap for clear lenses such as the ones at the retrofit source to improve the light output? I'm looking at making a custom pair of Gen 4s but swapping out the projectors would be a gigantic pita.
#445
Guys I got gen. 3 ccfl projectors and an hid kit for both lows and highs, but Im having some trouble with the installation on the hids and the ccfls... First of all, everything works perfectly on the driver's side headlight I wired ccfls and leds to the ccfl inverter then used quick connects to tap into the running lights. On the passenger's side, only the leds light up when i turn the running lights on, the ccfls stay off and the setup is the EXACT same. The only thing I can think is that the ccfl inverter on the passenger side is bad.. Other than the fact it looks like it got run over by a lawnmower and someone glued it back together, i hooked the passenger ccfls to the driver side ccfl inverter and they worked like a charm.. So Ill be calling them today and requesting a new ccfl inverter be overnighted.. OTHER than that..
The hids on the passenger side are reversed.. What I mean by that is that the highs are on when the lows should be on and vise versa. The high beam ballasts are being powered off of the relay harness but the low beam ballast is getting its power from the factory wiring. Does anyone know what I am doing wrong
#446
Are you sure you didn't just hook up the bulb to the wrong ballast? Not trying to insult you just going over the basics. Also I would run both the low and high beams off of a relay harness. Other than that idk, I've never ran a high/low hid setup and 3rd gens. Did you try unhooking the high beam setup completely? I would work on making sure the low beam setup worked completely before hooking up the highs.
#447
But another question about the relay harness... The bulbs that came in the gen 3 projector were 55w, so how is it that both the 55w high and low beam bulbs can run off of stock wiring but I need a relay harness for a 35w hid? Doesn't make much sense to me. For now I'm running lows off stock power and highs and fogs get a relay harness.. I'll get another one for lows when I have the extra cash haha
#448
I'm having the same sort of problem with the gen 3... The highs are blinding but the projectors are surprisingly dull.. Especially with a 6000k HID, I feel like they aren't nearly as bright as they should be. I had a 6000k bulb in my stockers and it projected a lot farther and brighter than the gen 3. The cutoff is crooked as well.. It's driving me in sane at night hahaha I had to stuff a piece of foam under the passenger side light and its still off by a couple inches. This is when I start to wonder if aftermarket is really the best way to go for functionality.... Looks, definitely, but functionality always seems to worsen.
#449
tommy i got a question for ya!
what size bulb do you have in your retros? i believe i have the same setup as you even though buyhids didnt make mine.. is it an h1 bulb or something special to fit in that "universal" projector we have??
all i know is its very thin.. but idk the specifics.. im looking to get a different temp
