06 recaros into an 07 lsj HELPP
Old Jun 26, 2014 | 07:12 AM
i944scania's Avatar
hey
so i got some recaros out of an 06 ss and put them into my 07 ss.
My 07 has the passenger airbag setup, where the recaros only have driver weight sensor.
what are my options to get the service air bag message and airbag dash light off??
The seats were swapped for mine and I did not have a chance to pull the old seat apart, so i have no spare weight sensor.
Any info is appreciated,
I have tried to search for this info and did not find much between the 30000 comments of unrelated chat in the forums.
Old Jun 26, 2014 | 09:19 AM
CobaltSS 16's Avatar
yes you need that weight sensor... basically you should have taken it from your old seat. You can buy another is the other option.
Once you have that part, you have to take the skin off the recaros and place the sensor underneath... there already is a slot for them on the underside where you would sit. I think there are pressure screws (like 4) or you can use adhesive tape to lay the sensor down. Once thats in, just put the skin back together and connect everything back... should be good to go.
Old Jun 26, 2014 | 09:30 AM
i944scania's Avatar
okay, sounds good thanks. how difficult/expensive do you think it is to find one?
Old Jun 26, 2014 | 09:37 AM
Xmetalhead2003X's Avatar
I put 06 ss leather seats into my 08 L61. All I did was swap the seat pans where the sensor is, then put the cushion and skin back together on top. You can buy the pan, I heard they aren't cheap. Might have luck at a recycler.
Old Jun 26, 2014 | 09:48 AM
i944scania's Avatar
hmm maybe thats the best option. if it did not have the sensor in the passenger, does that mean those seats are from a redline, and not an 06 ss?
Old Jun 26, 2014 | 12:07 PM
They were probably from a redline. Not sure when recaros started in the ss. The headrest is definitely a different shape with the redline vs the ss.
Old Jun 26, 2014 | 12:14 PM
Staged07SS's Avatar
Administrator
Administrator
Recaro seats were available in Cobalts from 05' to early 07'.
Old Jun 26, 2014 | 12:41 PM
Hockeyman's Avatar
I have heated recaros in my 07. I swapped all the guts/sensors/heaters from my 07 leathers. No issues at all.
Old Jun 26, 2014 | 02:33 PM
Bass_Waves's Avatar
Get a sensor from a reg cobalt.
U need it to get the issues to clear up
I have blue Recaro in my 07 ss. I did not swap the heated pads as I ain't need em. I did do the pad. Its easy to do. Takes about 15 mins .
Old Jun 26, 2014 | 07:09 PM
Yeah I when I swapped mine, I had both seats apart and back together in under an hour.
Old Jun 27, 2014 | 07:31 AM
i944scania's Avatar
awesome, yeah i should have gutted the old ones before i got rid of them.
the issue is, people want to much money for the pad. Maybe getting an old base model seat with the sensor pad from a junkyard for like 75 bucks would be best.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
