aftermarket steering wheel question
Old Jul 3, 2011 | 08:24 PM
sloobaltss's Avatar
I ordered my momo hub, nrg quick release and nardi steering wheel, and I should have them in by friday. I need my horn to work, but someone told me it wont work with an aftermarket wheel. is this true?
Old Jul 3, 2011 | 08:26 PM
JaredMeyers's Avatar
i think it depends on the steering wheel but i think most should just plug in to the horn wire
Old Jul 4, 2011 | 02:47 PM
sloobaltss's Avatar
ok , so the horn is just plug and play then?
Old Jul 4, 2011 | 02:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Not plug and play. It could probably be done but I didn't want to mess with it
Old Jul 4, 2011 | 02:53 PM
jefferyss's Avatar
It will work just fine as long as your hub has a horn wire option attached to it.not all hubs come with a horn wire inside them.if yours does just hook up the wires and go from there.if there is no wire inside your gonna have to do some modding and wire running lol
Old Jul 4, 2011 | 03:09 PM
sloobaltss's Avatar
so what did you do to get your horn to work? and did your hub have a horn wire?
Old Jul 4, 2011 | 03:54 PM
BLAZIN07SS's Avatar
I'm too JDM for you
The hub did have a horn wire but it was weird cause it only had one wire, the nardi button had two. I just have an aftermarket set of hella horns to a separate switch
Old Jul 4, 2011 | 06:09 PM
my friend has a momo steering wheel in his 3000GT and it was pretty much plug and play
Old Jul 4, 2011 | 06:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Sorry to inform you these cars are not 3000gt's. Lol they don't even make a momo hub for us
Old Jul 5, 2011 | 12:45 AM
sloobaltss's Avatar
Shoot I ment sparco hub not momo. Thanks man I'll try that out when we do the install
Old Jul 5, 2011 | 07:51 AM
BLAZIN07SS's Avatar
I'm too JDM for you
They have a Momo hub for us but only through cobalt addiction. It's a modified momo hub that it machined to our spline count
Old Jul 5, 2011 | 11:06 AM
jefferyss's Avatar
if the momo hub has only 1 wire comming from it and the horn button has 2 wires, the 1 wire goes to the horn button and the ground off the horn button you would run a wire to tuck under neath the main nut that holds the hub to the steering colum.this completing the circut when the horn is pushed.this extra wire will be the ground.
Old Jul 5, 2011 | 02:31 PM
i know that cobalts arent 3000GTs i was just using his car as an example
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
TedSS
26
Oct 10, 2015 04:30 PM
