dash light question.. asap..
Hey guys,
So, I went ahead and bought an ac panel off eBay. It is a black LS style one. I got it because I'm doing up my trim in black. Regardless, I got it in today. Excited to hook it up, I did so as soon as I got it in. I didn't actually use that assembly, just the front face that was black. Everything worked fine. Until night. I then realized that one of my bulbs in the ac panel was burned out all of a sudden. It was fine yesterday. So I swapped it out with the one I got. Same thing. I then put the other one back and somehow I now have two out. The center bulbs are fine, but both end ones are burned out. The 1-2-3-4 is good as well as the center parts of the temp and the airflow are lit well, but the outside edges are dim from the lack of light suddenly. Not a big fan. I noticed that the little bulbs do seem quite flimsy. I likely just bumped one and it got screwed up. Is there any way to fix that? I assume it's one of those things where you just need to replace the thing. Screw that. I'll work something out or just leave it. I was thinking about doing something where I remove that passenger airbag warning thing and make a small blue LED light bar that shines down on it. I think that'd be neat. But I'd really rather it just work normally. lol. Any suggestions or am I kinda screwed? Doing the dash trim painting in the morning, so just curious if there's anything I can try..
Thanks!
Thanks!
It basically is set up where there's a bulb and there's the two metal wires coming off them to get power. Just pull those off and solder a similar light in place?
haha Indeed. That's why I went back to the stock header/dp. I'm just keeping the car as-is for awhile. Tired of always fixing something. lol. And it's generally stupid stuff too!
z28addiction
Sep 28, 2015 12:03 AM
