Guage Lighting
Old Aug 18, 2006 | 08:45 PM
0624SSCobalt's Avatar
Guage Lighting
I was just curious if there is any way to change the bulbs behind the guage cluster
Old Aug 19, 2006 | 12:25 AM
SilverSS/SC's Avatar
The stock bulbs .....errrr , not really . You could if you knew how to solder and work on circuit boards . The cobalt cluster uses 2 tiny little LED looking incandesnt bulbs in each guage mounted in the center . After seeing how small they are , I cant believe the even light up the cluster as well as they do .
Good news , there is a complete a$$load of room to use LED's as backlighting , if ur skilled enuff .
Old Aug 19, 2006 | 02:58 PM
biohazard's Avatar
Get low
ya i was going to resolder green leds in there but they will only shine up, which would work b/c it hits the plasticy thing but will be very dimm
Old Aug 19, 2006 | 03:03 PM
Yeah , it woulda been pretty hard to project the light right mounting them in the center like that . Good thing the about the entire rest of the gauge are is open underneath the gauge faces .
Old Aug 19, 2006 | 03:05 PM
Cobalt_SSTuner's Avatar
how about changing the bulbs in the cd player or by the a/c controls? If i had to guess it would be the same setup?
Old Aug 19, 2006 | 03:12 PM
Its the same type of bulb . LED appearing incandesnt . As long as you can solder and use the correct resistors LED's could be used there too . For the AC controls so they light uniformly , and when I get around to doing it (lol) ,,,,Im gonna just run a circular string around , behind each knob so all the markings light up correctly . Seeing as how there is probably on a couple centrally mounted incandesents that shine thru a clear light diverter to guide the light . Most GM Hvac controls are that way .
Same deal with the all the lighted switches too , like power windows ect ect . If you can get the switch apart without wrecking it , the same as above applies .
Old Aug 21, 2006 | 07:00 PM
So...... I am pretty much S.O.L. on doing this mod then huh? Cause I don't know much about soldering.
Old Aug 21, 2006 | 07:25 PM
2006BlackSS/SC's Avatar
the radio one i did looks good all i did was use a dry erase marker on the buttons on the inside and also on the clear plastic pieces ill have a how 2 up within the next few days
Old Aug 22, 2006 | 07:03 PM
Cool... I will have to keep an eye out for that. Does it have to be a dry erase? Or can it be any kind of marker?
Old Aug 22, 2006 | 07:08 PM
SSinPhilly's Avatar
be careful i dont think your warranty covers you if you light your on car on fire.....and it any electrical problems happen down the line your screwed if they try to attach it to you putting new led's in. just a heads up. good luck!
Old Aug 22, 2006 | 07:09 PM
SSinPhilly's Avatar
use a cold/heat lol
Old Aug 22, 2006 | 07:34 PM
SSnightwolf's Avatar
what if we put colored flim on the back of the gauges like biohazard did with the ac/ controls????
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
