Has anyone fixed there misaligned front bumper?
Has anyone fixed there misaligned front bumper? The same problem everybody has with the passenger side gap in between the bumper and headlight. If so could you post a how to? thanx
nope i was told by my dealer and 3 others that there is no fix its how the plastic fits i also have a gap on the drivers side headlight that i can stick my thumb in but not on the pass side i can only stick my pinkey in
ps no perveted jokes about me fingering my car.. |
so why doesn't GM give us a new bumper b/c i feel like im getting ripped off
i was told it would fit the same way my responce to this is RKSPORT body kit and fill in all the lines
yeah i really don't feel like spending more money when the stock kit looks good if it fit right
I don't think the ricers will notice any mismatched body lines on our front bumpers. ;)
I can't give ya' a "how to" but I pulled the whole bumper off, and when I sat it back on there, I tried to set it a little lower. It worked for me... no more gap. There is a TSB for it on here somewhere... but if you have a couple of hours and a garage... just pull it off yourself and see what you can do.
cool thanks guys
i also have a misaligned hood ...there is a wider gap b/w the hood and the DS front quarter than there is on the PS
:cssNET: the only gaps im noticing are the ones that i put on the car behind me:cssNET:
today i talked to one of the guys that works in the plant( an executive) and he told me, they try their best to make it look nice, there is supposed to be an even gap all the way around the headlight, it was designed not to touch, but working in a assembly plant myself, it is hard to do it perfect when u have to do it 400+ times a day, it gets old and all that, i was told there is a little bit a play left with the headlight, how i dont know exactly, but it the headlight you have to play with, not the bumper
I've got the same thing sethallen. I don't notice the bumper misalignment as much as the damn hood alignment.
I brought that post about how to fix the bumber to my dealer and he told me it wouldnt fix it. I am beginning to think that they dont want to fix it because then they would have to fix all of them.
my brother's new civic has some misaligned fenders...so i don't feel too bad
I know some other guys said they were going to try to fix the bumper fit. lets hear from them.
i got the fix
well here it is.
through my own experimentation i found the solution. what you have to do is remove the headlight. there are two screws on top then remove the wiring harness you will then see a black plastic platform that hold the headlight in place. there are two screws in front very low then i think one or two at the top. after removing the black plastic housing you will see the frame of the car. remember those two screws that you removed from the front you will see a braket that is attached to the frame. one screw holds that braket in and then the braket will slide back and forth. move the braket forward a small amount and with a little trial and error you can remove the gap. hope this helps everybody. |
