HOW TO: disassemble/reassemble interior door handles
If you have a Cobalt, chances are you've experienced a peeling interior door handle. You can buy a new replacement or buy a used replacement from a boneyard. In my case, the boneyard only had gray bezeled handles and I needed black. So, I decided to swap the peeling handle for one that was in good shape.
To take apart the handle, first remove the door panel and pop the handle assembly out of the panel. There is a plastic pin that holds the handle to the assembly. use a screwdriver and push the pin from the top side out the bottom.
To reassemble, you'll need to take the cover off the back. use an X-acto knife to trim off the plastic welds that hold the cover in place.
you need to remove this cover to reinstall the spring.
Push the pin back into the bezel and into about a third of the handle. Set the spring in place. There is a notch on the handle that the short leg of the spring rests in. The longer spring leg rests against the notch on the handle housing. Align the spring and push it down while sliding the pin the rest of the way through the handle.
Replace the back cover and use a solder iron to melt the plastic posts to the cover
Thats it!
Thats it!
