installed my hids/projectors need help PICS
Old Sep 27, 2009 | 10:17 PM
pickin my brother up's Avatar
i installed my gen 1 projectors and 8000k hids (didnt get to wire the halo leds yet though)
i bought the projectors used and my question is if the aiming is already good since they were used?
also, when ever i turn my headlights on or switch to hi beams, the lights start really dim and then get brighter and sometimes blink a little. is this normal?
lo beams/fogs
hi beams
Old Sep 27, 2009 | 10:19 PM
cobalt123's Avatar
couldnt tell ya, i see red x
Old Sep 27, 2009 | 10:21 PM
really? i dont haha. can someone else confirm that the pics dont work?
Old Sep 27, 2009 | 10:23 PM
JL-KA's Avatar
I see pix. Not sure what the cutoff is supposed to look like on gen 1's tho.
Old Sep 27, 2009 | 10:24 PM
cobalt123's Avatar
oh wait now i see them i guess it was the sight lagging haha
JL-KA's Avatar
And just because they were used doesn't mean they were aimed. I just got some from a guy and they needed to be aimed
oowah's Avatar
they work for me
They don't look too badly aimed.... why don't you get some masking tape and a tape measure and check if they're aimed properly tho?
Old Sep 27, 2009 | 10:27 PM
its looks a little weird right? like steps going up from left to right. im not sure what any cutoff is supposed to look like, but i know the high beams look like they dont go far enough to the right like it just stops.
any info on the blinking and dimness i see when i first turn them on?
Old Sep 27, 2009 | 10:29 PM
c0ld29's Avatar
get on a level surface 25ft away from a wall. Lows should be one inch lower on the wall than the height from the ground to where the projector is in your headlight.
As far as the flickering/dim to bright, thats normal for HIDs, they will start off dimmer and get brighter for a few seconds. Mine only take about 3-4 seconds, another friends kit would literally take about 30 seconds to brighten up all the way.
The cut off is also supposed to look like that, thats how projectors work. Just aim them straight ahead and like I said before.
Let me correct that, each headlight will produce a patten like ____/````` but the lower line should line up horizontally from the driver to passenger headlight, not have a step up on each one.
Old Sep 27, 2009 | 10:49 PM
jefferyss's Avatar
this is what they should look like once they are adjusted and done
Old Sep 27, 2009 | 10:51 PM
Acey's Avatar
Your SS badge is upside down.
Old Sep 27, 2009 | 10:53 PM
platinumrims's Avatar
looks like the driver side lens is rolled upside down, or a height adjustment lol.
Old Sep 27, 2009 | 10:54 PM
dman090's Avatar
it appears that the driver side headlight needs to be moved to the right and up a little bit, but you got them pretty close as is, id leave it like that
Old Sep 27, 2009 | 11:01 PM
jefferyss's Avatar
straight line across the wall and the right (passenger ) side cvan even be a little higher....basically the drivers side 1 how it is a straight line /notch/straight line and then you would match the passenger side 1 line even with the drivers last lifted lin after the notch.
______/-------- _______/-------
Old Sep 28, 2009 | 08:51 AM
BLK08SS/TC's Avatar
The flickering is usually if you hook the HID's directly to your factory wiring, if you were to use a harness that pulls power directly from the battery you would solve that problem. Yours beams are not aimed properly, they should be level straight across not step up on each side. You either need to raise the driver side or lower the passenger side which ever needs to be adjusted. They should look like this:
Old Sep 28, 2009 | 11:50 AM
TommyP's Avatar
AWD > FWD
ya that's about right. The flickering sometimes happens with hids when they are warming up. Mine take about 10 seconds to warm up, but it's worth it. Also, to Jefferyss, might I recommend that you do the anti-glare mod for your headlights. I'm guessing you have the 3rd gens? Those spots of light on your garage door are causing huge amounts of glare for others. When I get home from school, I'll add a pic to this to show you how mine look after aiming/ anti-glare mod.
Edit: pics added
Honestly, I could aim them a little better, but I like them the way they are now. Also, this is uphill, which is why they seem so high.
Old Sep 28, 2009 | 07:13 PM
SSPainter's Avatar
lol
Old Jan 20, 2010 | 09:09 AM
Terminator2's Avatar
Those 3rd gens need the antiglare mod done to them.
dennis69
Oct 20, 2015 04:49 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
