LED help
LED help
i wanna switch to LEDs for my dash gauges ive been looking around but cant realy find a how to with pics that havent been deleted. i have never done this befor could use all the info i need. where to order the stuff sizes resistors ect. please help me and if u do thank you very much.
yeah I did mine.. it was easy, just dive in and you'll see its no big deal.
I just ordered 300 5MM LEDS ($2/free ship) I used some odd blue ones that came in the back for the gas gauge, and came with free resistors, I soldered the resistors on the soldered the LEDS to the board.
except I went a bit nuts and added like 50 LEDS .. but yes it is dimmable
is their a how to thats like step by step of how to do it where to put the bulbs soder it to where where the resistir goes... ive never done this before.
so before the resisitor as in right after the resisitor or befor the resistor cutting it off? r theis bright? also do u know of a different how to on this lol
no i dont have any one that can help thats y i asked for a step by step kinda how to... i can soder ive had to do it in the automotive glass i took through high school.i just gotta have a good sodder gun with a fine point.
Well taking it apart is simple, just keep track of order of thinks and install in reverse order. once you
get it all taken apart there are nine bulbs, you take some needle nose and just bend and twist and they
will break off. Then you solder one Led on and take it out, plug it in. If it doesnt come on its
backwords. Then you know if positive goes on top or not. And on the LED the positive wire has a
resistor right by the bulb, cut the wire after that. To take the needles off you just twist counter
clockwise and pull up. It will take some playing around to get them set back right.
yeah I bought the LEDS w/free resistor because it was dirt cheap for a **** load of lights and I'm pro (lulz) at soldering so popping some resistors in there was no big deal at all
and I know the idea of taking a cluster apart is may seem daunting, but you really do have to just dive in, and if you're THAT worried, start with the HVAC, its super simple to pull apart and the bulbs are really easy to get at and work with.
yeah I bought the LEDS w/free resistor because it was cheap for a **** load of lights and I'm pro (lulz) at soldering so popping some resistors in there was no big deal at all
and I know the idea of taking a cluster apart is daunting, but you really do have to just dive in, and if you're THAT worried, start with the HVAC, its super simple to pull apart and the bulbs are really easy to get at and work with
ok then the only thing i need to know is r all the gauges HVAC door controls steering wheel all the 3mm? and also is their a site that has good bright white LEDs that sell alot for a good price since once i get a hang of things ill wanna do everything
