Official Retrofit Thread
#1253
I really don't care. I'm just pointing out that if you want to hook your halos up this way and have them stay on with your headlights, they'll only stay on with the low beams. My first plan was to just leave the diode out and only have the halos run when the headlights aren't being used.
And here's to clear up any confusion on how this works.
Also, I had to bend the contacts for the fuse tap so I can get it to install in the way it'll work properly, since that "2754" relay is in the way.
#1254
I have the 9007/9004 wire harness from TRS.
Am I correct that the orange connection labeled "projector" doesn't actually connect to anything.
I have the H1 bulbs and the two wires coming out of the bulb both have their own unique connect that fits the connectors from the 3 Five ballast. Does this connect just not get used?
#1256
By "it" you mean the connector with the orange gasket? That should connect to the solenoid that controls the high beams? Maybe I'm dumb, but those wires coming out of the solenoid appear to be only 1/2 of an alligator clip.
#1257
Yes the connector marked PROJECTOR. If you got that from TRS your kit should have come with 2 empty connectors and grommets that you run the red wires into and connect them to that plug.
#1260
Is it worth paying 34$ shipping plus the 10$ ? XD is there anything that can be bought at a local store that will work just as good?
#1261
I haven't had any issues with the TRS glue either. I'd say it's worth it. One roll will probably last you about 5 retrofits. Had to reopen my lights twice to upgrade the foreground limiters on my Mini H1s and fix a sticking solenoid issue. I still have more that enough for my EvoX-R retrofit.
#1262
Alright!!! My retro's are almost complete. Only thing left to do is wire the xbAled halos to the turn signals, which happen to be switchbacks. (HIDWERKS!!!!)
Has anyone done this before? I am sure that I could puncture some wires and activate the turn signal to hunt down the wire with a volt meter...
edit....
Didn't like they way the halos got out of sync with the switchbacks so I reverted them back to the brown wire (parking/daytime running lights).
Everything has been wired and will post photos in a bit!!!
edit....
#1268
#1269
At 25' on level ground you should measure from the center of your projector or reflector to ground, take that and subtract 1-2". That measurement is where you want your line on the wall. Everyone's height will be different based on vehicle loading and suspension/tire setup. Mine shoot a little low, need to get around to fixing that.
#1272
#1273
I believe so. Quite a few people already have them. I have mine all blacked out, including turn signal (gloss black turn signal, gloss black shrouds and such, flat black oem halogen reflector)... Triton V3's switchbacks definitely work awesome with all blacked out look.
