Taking Gen 1's Apart
Can only find info for stock headlights... starting a projectn tommorow on my first gens, have new ccfl halos, new leds, and a ddm hid kit. Question is how long do i cook them for at 200 degrees? not too sure if its any different from the stock ones.
I just used a hair dryer when i opened mine. Make sure you take the screws out on the hold the lens before you start prying.
i've done about 15-20 sets of lights now. i always put them in at 230 for about 8 and a half minutes.
thanks guys i'll throw some pics up asap, im probably gonna crack em open tonight and finish it all tomm, the wiring may take me a lil bit to figure out
what do you guys reseal them with?
get this
OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc works fantastically. And you take them apart the same as stock. |
I just used clear silicone.
I pulled my first gens apart to do the CCFL mod as well a couple years back, just follow the oven directions for the stockers. Also don't forget to pull the 3? screws in the back before you bake em.
I resealed with windshield sealant, holds and seals like a mofo but if the time comes to separate you just pull and it comes apart. Also might want to put a pair of OEM lenses on while you're at it, the ones that came on mine were peeling. |
I just used the original sealant , just heated it up and stuck it back together
Originally Posted by YelloEye
(Post 5888249)
did you guys clean out all of the grey sealant or just leave it and reseal?
I took all the gray stuff out of mine.
I left all mine in, no new stuff, ZERO fogging issues
ive been going strong about halfway done just need to get a lil more of the sealant off, hopefully these will be closed tommorow and i can wire em up in the am
just heard a small crack when i was applying pressure to glue one of the halos down, im kind of scared now
