Tried Painting Interior Trim
Old Apr 1, 2010 | 04:25 PM
druwatters's Avatar
So I painted my interior and right after the paint was applied it started to crack. WTF did i do wrong. I painted my bowtie earlier in the week and it came out ok but to dark cuz i ws trying to fill a chip. I'm thinkin wrong primer or something.
Old Apr 1, 2010 | 04:34 PM
silvercobalt07's Avatar
mine did the same thing but it was in one little spot n idk how it happened so i doubt it was the primier
Old Apr 1, 2010 | 04:35 PM
Gestapo007's Avatar
wrinkling. I hate that. Sand it, then respray it. Only wait a few minutes between coats with spray bomb, and apply LIGHT coats. see if it fixes your problem. Wrinkling usually occurs when you apply a heavy coat of paint over a surface thats hard but not cured yet. I imagine if you waited too long between primer and color and you sprayed your 1st coat heavy that will happen.
Old Apr 1, 2010 | 04:38 PM
07cobalt2.2's Avatar
This may sound dumb but was the room to cold? like a garage or something, my friend tried to paint her interior trim out side in 50 degrees, dumb. It turned out all cracked haha.
Old Apr 1, 2010 | 05:03 PM
Shez's Avatar
Did you spray lacquer on enamel or the other way around? Don't know if that'll make it wrinkle. I know it ***** it up.
Old Apr 1, 2010 | 05:24 PM
ItalianJoe1's Avatar
That's it.
Old Apr 1, 2010 | 05:49 PM
idr u saw mine tho joe mines small so idrc
Old Apr 1, 2010 | 06:04 PM
druwatters's Avatar
I waited 24 hours after priming it. And it ws in my garage but it was like 63 degrees today maybe i just applied it to thick SOM is ******* hard to match too. Maybe better off having someone pro do it since i must just suck with a rattle can.
Old Apr 1, 2010 | 06:59 PM
Gestapo007's Avatar
Dont have some1 else do it, its simple stuff. Dont wait 24 hours after priming. You dont really even need to prime rattle can on plastic since they make rattle can color that stick to plastic, its completely unnecessary. but since your going to be sanding the **** out of it now to fix it, id throw some primer on it just to kinda add more material down to fill in those sand scratches your gonna make. Once the primer flashes in like 3 minutes and it doesnt have a gloss to it anymore, spray your color. Dont wait 24 hours, real car primer only need 3 hours before sanding.
Old Apr 1, 2010 | 07:07 PM
outtamymind's Avatar
also use the same brand primer and same brand paint. do not mix paint brands and if your using a clear coat use the same brand clear coat as well.
druwatters's Avatar
Thanks for the the advice Gestapo I will try that. If it doesn't work I have to have a pro do it because I do not know anyone that could do it for me, and I just want the dash put back together. And on a side note never tried spray paint before this and I didn't even get the color even. I think it would be worth the money to just have someone do it for me it's pissin me off.
Old Apr 1, 2010 | 07:21 PM
Gestapo007's Avatar
just sit it on some newspaper on a table, and just move around it as you spray it, do light coats, you can do a bunch of coats it dont matter, dont try to cover it all at one time. And you really dont need to clearcoat it. They dont make interior pieces shiney for safety reasons. and rattle can has enough gloss to it to be good for interior pieces and not too much at the same time. If you really went ***** out and did it, you can have it done in like 2 hours. Sand it with some 300 grit till its smooth and you cant feel the wrinkles any more, get some windex and wipe it clean (dont touch it anymore after this part, greasy fingers will fisheye the paint) hit it with some primer, 2 medium coats, wait 5 minutes, spray your color, when its all the color you want it, your done. Let it dry for liek a half an hour, and if you wanan install it that same day you can put the pieces in your house oven on its lowest setting for a few minutes. My oven's lowest is 170*, i put **** in there with the door closed for like 3 minutes, then crack the door open and let it sit a bit longer. I just try to keep them warm and the paint will dry pretty quickly and you should be able to handle it in no time.
Old Apr 1, 2010 | 07:23 PM
druwatters's Avatar
I think my mind can't grasp how to DIY, much easier to waste money and get it done.
Old Apr 1, 2010 | 07:28 PM
Gestapo007's Avatar
Hey man do what you gotta do, people out there need to make a living too
Old Apr 1, 2010 | 07:31 PM
druwatters's Avatar
I will try what you said first I just want it to look good and thanks for the tips
Old Apr 1, 2010 | 07:51 PM
Gestapo007's Avatar
no problem bud
Old Apr 1, 2010 | 08:39 PM
druwatters's Avatar
well I fixed it so there is no cracks but damn that **** doesn't even get close to looking like the Orange on the exterior. Im starting to think me + modding = bomb. Cuz I **** everything up. Maybe I should trade in for a Celeberty seems to be more my speed.
Old Apr 1, 2010 | 09:24 PM
Gestapo007's Avatar
lol you didnt realise the color didnt match at all when you sprayed it the 1st time? Lol. Well either just say hell with it and install it, or try to find a better matching spray paint, or bring it to a professional. But red and orange pigments are the most expensive so it may cost a little bit. nothing crazy for that little bit though
Old Apr 1, 2010 | 11:00 PM
druwatters's Avatar
no the paint matches its GM paint i just cant get it to look the same. But I'm just gonna have someone do it I found a friend of mine from highscool that does custom work. I just can't beleive I can manage to do anything mechanical but yet can't ******* paint ****. oh well can't win them all.
Old Apr 1, 2010 | 11:03 PM
Gestapo007's Avatar
lol at least your cool about it
Old Apr 1, 2010 | 11:04 PM
RecklessL61's Avatar
dont know if any one said this yet didnt bother reading though it but you but to much paint on at once you need to sand it down to the plastic and start over, wipe it down with rubbing alcohol after sanding and let it dry then just lightly spray it the first 2 or 3 coats will just look like over spray, same thing happend to me took for ever to figure out what i was doing wrong
Old Apr 1, 2010 | 11:29 PM
don't worry i have this problem as well lol
Old Apr 2, 2010 | 11:48 AM
druwatters's Avatar
Well it's good to know I'm not the only one.
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
