Why did my debadge do this?
Old Jul 2, 2011 | 02:32 AM
KCobalt's Avatar
There is nothing left but you can still see where the letters were. Not sure if its visible in this picture but it is during the day.
Old Jul 2, 2011 | 02:36 AM
alleycat58's Avatar
Either there's residual adhesive or you used adhesive remover that's damaged the paint. Could also be that the area covered by the letters was protected from the sun, keeping its color while the rest of the pint faded.
Old Jul 2, 2011 | 02:38 AM
KCobalt's Avatar
I'm guessing the paint faded option, any fix for that?
Old Jul 2, 2011 | 02:44 AM
alleycat58's Avatar
If it's clearly defined (which it looks like it is), fading would be my guess, red cars fade the worst. Take it to a detailer and ask them, they can probably do a paint correction/restoration that will make the two shades match, but it'll be pricey.
Old Jul 2, 2011 | 02:46 AM
KCobalt's Avatar
Eh, I need to do some touch up paint to my bumper so when I do that I'll just sand that spot and repaint it myself.
Old Jul 2, 2011 | 02:56 AM
alleycat58's Avatar
YIKES! Unless you're a pro, it's going to look worse. I would only do that as an absolute last resort. Read up on some of the detailing theads on here, a GOOD wax, maybe a claybar, would be a great place to start, see if just cleaning up the surface that was debadged and surrounding area will make it blend together better.
Old Jul 2, 2011 | 03:25 AM
Mradjr9005's Avatar
rub in some more bug n tar remover or wd-40 works too (DOESNT HURT PAINT)! lol then wax it real good, if it didnt help get a clay bar and buff it
Old Jul 2, 2011 | 03:27 AM
AndrewSS/TC's Avatar
Try a claybar.
Old Jul 2, 2011 | 03:30 AM
JL-KA's Avatar
polish it with an aggressive compound. might help some.
Old Jul 2, 2011 | 03:50 AM
alleycat58's Avatar
WD-40 is a debadging godsend.
Old Jul 2, 2011 | 09:57 AM
Rocky87's Avatar
its just faded, you need to polish your car
Old Jul 2, 2011 | 10:01 AM
whyyoumadson?'s Avatar
that might not even help depending on the extent of the car. mileage, aftermarket paint(if its been painted) and so forth.
reds fade pattern is pretty shitty compared to most others and if its real bad then good luck. even after a polish you will still see it. doesnt hurt to try though at all.
whoever said use touch up paint...dont even bother. you need someone with a wool pad, a good compound and some polishing compound and foam pads to do the trick.
Old Jul 2, 2011 | 10:47 AM
cmcphi1195's Avatar
I used a rubbing compound.
Old Jul 2, 2011 | 12:19 PM
EmperorJJ1's Avatar
i had the same issue on my car. idk how bad urs is bc i cant see it really from the pic BUT i just used mild rubbing compounds a few car washes and let time and sun go at it and eventually it was just fine
Old Jul 2, 2011 | 12:23 PM
heathkidder's Avatar
use a ultimate compound on it and buff and wax. try to use clay bar as well
Old Jul 2, 2011 | 01:06 PM
ecot3c inside's Avatar
polishing compound will work very well.. any other wax wont do dick.
Old Jul 3, 2011 | 12:37 AM
Mradjr9005's Avatar
lol it works great for it
Old Jul 3, 2011 | 12:41 AM
cmatthewb101's Avatar
It's honestly hard for us to say since we can't see it in person. It's either residue left over, or faded. Can't say for sure though....
dieGone
Sep 23, 2015 10:20 AM
toledobalt
Sep 2, 2015 07:04 AM
Asphalt Assault
Dec 8, 2006 03:51 AM
D4u2s0t
North East
May 9, 2006 07:23 PM
Wyoming_Bass
Apr 12, 2006 05:38 AM
