Not not try and beat this into the ground, but is there an official place where it says this can or can not be used in STX? As it seems, there is not. Does anyone know where to get an official answer of yes or no on GSM1 in STX?
Originally Posted by Force
(Post 4537205)
Is Stage 1 really changing stock boost levels, though? The car can achieve 22psi of boost stock, it's just rare that the PCM ever calls for it. So by simply fixing the boost at the stock maximum (which as far as I know, Stage 1 does), can you really consider it increased?
I guess this falls under modifying the boost controls, though. my gms1 has hit up to 25 psi, ussually its around 20-22 it does what it has to , to hit 280 /320 just like the stock tune does what it has to , to hit 260/260 |
Originally Posted by tommyk
(Post 5998408)
Boost
Originally Posted by Mark Aubele
(Post 5998568)
Yes. You can't raise boost in STX, period. Can't do it. Therefore, GMS1 is illegal in STX. Run in DSP.
I was going to protest a fellow competitor years ago. I talked to the competitor before hand. I believed what they were doing was allowed but nobody had really said anything. So at the event I made it clear that I wanted to protest. Then the head person came up to me and said they checked and explained that within the rules my issue was allowed. So if I was to protest, it would not be upheld. Did I still want to protest? I had my answer and did not have to actuall protest anybody. The issue then was similar to ours now. Traction control is what was then SM2. It is done by altering fuel and ignition and both are free in our class. My thinking if this issue was pushed if the Stage one kit is allowed or not, I think it would be as long as it can be shown that only fuel, and ignition are the only things altered and both are free in SP class. I have found no writting that states the kit manually or by computer changes the boost level. It only changes the fuel, ignition. Just my 02. I also know that if your race quite abit, most of the top guys in each class know who each other is. If you are doing something and is clearly wrong, it should not be done. However if it is a grey area, none of the top guys will protest because they know you won because of your ability not because of fuel and ignition. Just putting in my take. Slowbalt |
If you want more power just run E85 with the stock boost. I allready checked with SCCA and its legal for all classes.
Originally Posted by mongorat427
(Post 6000169)
