Dunlop Direzza ZII, releasing spring 2013
Dunlop is releasing a successor to the Direzza Z1 Star Spec, the Direzza ZII. Unfortunately, looks like it's only in Japan this year and won't be released in the US until probably next year. Dunlop is claiming more grip, more consistent deformation, reduced track wear, and 1-2% faster on their test tracks (0.6-1.2 seconds on a 60 second course!)
They will be running nice and wide too which will make it quite the "cheater" tire (at least prodominantly for those running 18" rims it seems). Ignoring the fact that its a Japanese site, heres the link to them and the size lineup with actual width specs
http://tyre.dunlop.co.jp/tyre/lineup...2/z2_size.html
For those not wanting to sift through japanese writing:
225/40/18 - actual width 231mm
235/40/18 - actual width 243mm
245/40/18 - actual wideth 249mm
thoughts? Depending on cost, I'm thinking 235's are going to prove to be the best option on a 8" wide pf01 in my case. paying the extra for 245's for an extra actual 6mm may not be worth it, not to mention I'm not sure performance will be great having that wide of a tire on an 8" rim. would seem to be pushing it
Looks awesome! I think my star specs will last me through next season but will definitely be looking forward to reviews from people. I like the bump from 225 to 231, that's my size
and I might be able to get my hands on the early :P Well atleast Imma try! thinkin I might give these a try over the NT05s
Talkin to the German tuning master here to try and get a set for me
for the redline I'm assuming? what size did you end up going with and what was pricing on said size if you dont mind me asking? Kind of interested to see how they compare price wise to the Z1's
yeah I was expecting $200+ tire. the Z1's 235/40/18 were at like $230/each when i was in the market for tires this summer. How high into that range the ZII will go I'm not so sure though, guess I'll have to wait like everyone else.
I bought a mid range tire due to treadwear (BFG KDW2's 235/40/18) at $175/each shipped this summer and I know the next set I'll be looking into something to get competitve with at AutoX. It will likely be this tire.
If I were you and serious about racing , I would get an extra set of wheels and buy a set of Hoosier A6 and screw the Z2's. The Z2's are great for both track and street , but the Hoosier for out and out competition is way better.
I paid 195 last fall for the set of Z1's I have now, and I begruded every penny. Cost me 145 each the year before from Discount tire direct before Tire Rack stepping in and grabbed the business from Dunslop.
but for what its worth, I dont think I'll be getting THAT serious into racing to warrant a race tire/rim setup. I just need something more competitive than the BFG's will get me that i can still DD on so I can easily match many of the other cars in my class around here... but that talk is all for when the BFG's are roasted and who knows how long that will be
These will be fairly awesome, that's a given.
I can probably squeak another summer out of my current Star Specs... By then I'll probably be looking at getting a track wheel/tire setup, and just needing something to "DD" the Cobalt on.
I wouldve got them but the tread life was concerning so I opted for something a little worse performing to hopefully keep a respectable amount of miles on this set of tires
12k on two, and maybe 3k on the other two. I picked up a nail so bad it wasn't fixable, so I went ahead and replaced two at once.
Shoulddd be able to get another summer out of the 12k ones, so we will see.
Vehicles used:
2012 BMW F30 328i Sedan
In the Extreme Performance Summer tire category, the Dunlop Direzza Sport Z1 Star Spec has a strong following among driving enthusiasts, autocrossers and track-day drivers. And it's for good reason — this tire has a reputation for delivering impressive dry traction and well-balanced capability in all directions of the friction circle — cornering, acceleration and braking. All this packed in a tire that you really can drive to and from the track.
When rumblings of its replacement began to surface in the summer of 2012, fans of the Direzza Sport Z1 Star Spec debated the pros and cons of any change while they waited to see if Dunlop could find performance improvements without losing the good in an already great tire. Dunlop's development target was simple if not easy: improve dry traction and handling without sacrificing any of the wet or wear characteristics of the Direzza Sport Z1 Star Spec.
Pavement-eye view of the Direzza ZII cornering hard.
What Dunlop came up with is simply called the Direzza ZII. Short and straight to the point, the ZII looks the part of a dry track performer that begs to be driven hard, with a more solid tread pattern than the Z1 Star Spec. Dunlop is bringing the Direzza ZII to North America in early 2013, and when it arrives we'll do a comprehensive road and track test to find out how it compares with other tires in the category. In the meantime Dunlop brought us a set of production-spec tires to try out before we closed our test track for the season. We also pulled a set of Z1 Star Specs off the shelf to benchmark the ZII and get an idea of how well Dunlop hit their mark.
As the autumn afternoon temperatures hovered around 60° F we set cold tire pressures to our standard tire test setting of 35psi front/rear, and scuffed in both sets of tires to wear off any mold release. We then got started by running some baseline laps on the Direzza Sport Z1 Star Spec. True to the tire's performance in past tests, this tire goes about its business with minimal fanfare and rewards a smooth driving style.
In many instances the balance of the car with Direzza Sport Z1 Star Spec tires has just enough rotation at the rear to help the car glide around the corner, requiring minimal steering input to manage the few degrees of drift. Aggressive or early throttle input powering away from the corner can create a little power-on oversteer, however. Steering behavior is relatively good as the tire drives down to the apex, but you have to lead it just a little bit or risk falling behind when multiple steering inputs are required. Maneuvers such as the multiple side-to-side inputs of our five-cone slalom, as well as the right-left-right of our increasing radius S-turns, reveals the one potential weakness of the Z1 Star Spec, where the rear can get out of phase with the front, resulting in some transitional oversteer if not driven smoothly. Earlier and smaller steering inputs help tame it, as does keeping some weight on the rear tires. Avoid big speed adjustments mid-slalom or risk the tail wagging the dog.
Direzza ZII's quick steering response had us driving over apex cones.
With the Direzza Sport Z1 Star Spec tires still warm from their exercise, we hopped into another of our test cars shod with the Direzza ZII tires and set off to see what they have. From the first turn it was apparent this isn't the same tire. The Direzza ZII displayed noticeably more direct and positive steering response from the front tires. So much in fact, that we ran over a few apex cones in the first half of the first lap due to how the car was now diving to the apex with real authority. Lateral stability through the slalom was noticeably better, with a considerable improvement in composure at the rear of the car. Acceleration traction was noticeably better too, as this tire let us use much more of the torque of our turbo'd BMW 3 series test car, allowing for harder and earlier throttle application that results in forward progress, not sideways motion as might happen with the Z1 Star Spec. It's hard to say that the Direzza ZII has significantly more steady-state lateral grip than the Z1 Star Spec, but it does use what it has much more effectively. This pumps up driver confidence in rapid transitions and high speed maneuvers, resulting in higher velocity and lower lap times.
We then turned on the track's sprinkler system to make a quick assessment of wet performance. Once the track was thoroughly soaked we had time in the schedule for just a few laps on each tire. Here the Direzza ZII again showed a noticeable advantage over the Direzza Sport Z1 Star Spec. The steady-state overall grip level was similar, but the ZII was much more predictable at the limit, with noticeably better communication of where the limit is, along with faster recovery once any slide began. It was just plain easier to go faster with the Direzza ZII.
Dry
Avg. Lap Wet
Avg. Lap
Dunlop Direzza Sport Z1 Star Spec 29.56 35.00
Dunlop Direzza ZII 29.08 33.84
Time Difference -0.48 -1.16
2012 BMW F30 328i Sedans using new, full tread depth 225/45R17 tires mounted on 17x8.0 wheels. Cold inflation pressure set to 35psi front/rear, with no adjustments made during the test.
We didn't run enough laps to begin to see significant wear on either tire, but what there was already showed the Direzza ZII was wearing at least as well as the Z1 Star Spec.
So, let's see — faster and more predictable in the dry and wet, and at least equal wear rate. Sounds like Dunlop hit the mark with the Direzza ZII. We'll be doing a full road, dry and wet track comparison in 2013 to see how the Direzza ZII compares with other tires in the Extreme Performance Summer category. Stay tuned.
Product Details
Dunlop Direzza ZII (Extreme Performance Summer): The Direzza ZII is Dunlop's Extreme Performance Summer tire developed for serious sports car, sports coupe and performance sedan enthusiasts looking for race tire-like traction on the street or for use in autocross, drifting and track events. Designed for drivers who want Dunlop's highest level of traction and handling in warm and dry conditions, Direzza ZII tires are not intended to be driven through snow, on ice or in near-freezing temperatures. Read more.
Dry
Avg. Lap Wet
Avg. Lap
Product Details
