track day Brakes
track day Brakes
I going to a track day and I am having my brake lines switched to stainless lines I also want the brake fluid flushed.
What fluid would you recommend and where can I purcahse it for the DD and twice a year track days? The track is Road America (high speed track with some very long and hard braking areas). I am running R1 premium drilled and slotted with Hawk HPS pads.
Your drilled and slotted brakes might be a problem - they look pretty but they aren't really what you need. They have a habit of cracking at high temps because of the drilling. Stock solid rotors are your best answer for the track day.
Scott
'Stock' brake fluid is quite adequate if you change it before you go to the track - every time you go to the track.
Scott
Scott
I will stay with my R1's. The good thing about Road America is that it has good distance between corners so you can cool a bit between corners. Its an over 4 mile course with 14 turns.
So you "warped" (I doubt you did, I am sure it was just pad deposits) your stock front rotors and you think the same thing won't happen with drilled and slotted rotors? Please, please, take that garbage off of your car before you go to an actual racetrack. They WILL crack. Leave the slotted and drilled garbage for the ricers.
Sure could very well have been from the stock pads. After I drove the next couple days I had a bad vibration whenever I would step on the brakes so I had these from my other car so put them on with the HPS pads. I'm sure I can find some blanks cheap enough for a couple days a year of track time.
Here is what I run on the car for a brake setup at Road America. Stock rotors with HP+ pads. They are a little much for the street but I don't drive the car that much. As far as fluid the DOT 4 blue stuff from Tirerack or Motul 600 which you can get at Pegasus in New Berlin. If you go to Napa and get rotors they are cheap so if they warp just put new ones on. IMO the drilled and slotted rotors are for show. HPS or HP+ pads will work just fine with your car.
Listen to Scott and Mark. You didn't warp the rotors. You used pads that weren't aggressive enough, and didn't tolerate the heat. Do not use drilled rotors on track! Only newbies do this. They will crack. If you're lucky, they won't connect the dots.
HPS are not track pads. HP+ are not track pads. Both of those will cause some massive vibration if you try to use them on track. I guarantee it. Use cheap stock rotors, fresh fluid like ATE or Valvoline synthetic, and spend the money on pads. Carbotech XP10 or above, Cobalt Friction XR1/2, Hawk Blue (super rotor aggressive), Hawk DTC60/70, etc are all appropriate track pads.
Personally, I run Cobalt Friction XR1. They're rotor friendly, and are very easy to get used to. The only downsides are the price and rivets, though the rivets are made of a soft metal, and will not score your rotors unless you try to run it all the way down to the backing plate.
Should you decide to run a fluid more exotic than Valvoline synth or ATE, keep in mind that anything that has a really high boiling point will probably also not have corrosion inhibitors. This means that you MUST, MUST, MUST bleed the brakes once or twice a season, otherwise your lines will rust from the inside out. Street fluids contain corrosion inhibitors.
If you want to use the same rotors, do some research on the Carbotech stuff. You could just run Carbotech street pads and Carbotech track pads. Their stuff is compatible with each other.
