Manitoba SS 2017
Old 06-21-2017, 07:37 PM
  #201
tomj77's Avatar
also, that sucks major man. where did this happen?
Old 06-21-2017, 08:15 PM
  #202
cluelessk's Avatar
Originally Posted by tomj77
if its not damaged where its illegal to drive it, which it isn't, and they write it off, u can take the money and keep the car, u just cant write it off again.
I know. That's what I was saying about buying it back.
I got the confirmation that it's a Total Loss. They gave an offer of $8100 right off the bat so I gonna try and squeeze 9k out of them. It'll have salvage/other title kind of like hail. No integrity needed.
Buy back is roughly $2000 so I'm just gonna do that. Put a windshield in myself at work and should cost around $200. Might get the hood pdr'd or just replace it. Polish the scuffs on the bumpers and drive it into the ground. It's at 180k kms so it's not worth trying to make it perfect.
In the end I'll have my other debts paid off and a decent amount left over for suspension and brakes.
Tom you ordered your complete spring and strut directly from Powell? Is it cheaper than going through CED? Thinking about getting control arms with his rear bushings right away too.
Not sure what I'm gonna do for brakes yet. I get GM stuff at cost so OEM might be my best bet.
Edit (Happened on the 311 about 2ish miles east of New Bothwell.
Old 06-21-2017, 09:24 PM
  #203
tomj77's Avatar
Good plan. Doesn't look there isn't too much damage other than paint, and u work at a body shop . could always get carbon fiber hood . My suspension was koni s on Powell springs and no definitely not cheap , unless u buy the springs and koni s and so it urself. I got all new parts assembled by Powell, my stuff was **** when I took it apart. But yyz springs and koni s are definitely worth it.
Old 06-21-2017, 10:07 PM
  #204
cluelessk's Avatar
Realized later that you had Koni's. I only need oem struts.
Old 06-22-2017, 12:04 AM
  #205
slapbetcommissioner's Avatar
I got the Ced yyz and new oem struts.
Old 06-22-2017, 01:50 PM
  #206
tomj77's Avatar
Go ced , probably best price u will find
Old 07-07-2017, 08:18 PM
  #207
Got Bewst?
Bluelightning's Avatar
Husky only sells 91 now? What the **** kinda bullshit is that? Ugh...
Don't let me down now ethanol lol.
Old 07-15-2017, 12:51 AM
  #208
Flatgod's Avatar
Holy crap it's been a long time since I visited this forum. Thought you sold your balt years ago Dustin.
Old 07-15-2017, 11:57 AM
  #209
Got Bewst?
Holy **** hey man! Nope still got it. Slowly saving up for a Vette haha. You still have yours? Last time we talked you bought a turbo kit from ZZP and were gonna build a motor.
Old 07-15-2017, 01:05 PM
  #210
yellow dragon's Avatar
Hey Dustin M, you were right. That rattle clanging sound from my back end was the axle pivot bushings. Ugh. So my options are buy new bushings and drop the axle and fight to get the old ones out. Or see of I can find a wreck Balt and with good bushings and switch out the axle assy and flip over my brakes. Found a couple at direct and team and they want 200, new bushings are around 100 each.... Choices choices. Swap the axle out would be less frustrating, new bushings well their new.... What to do? Thoughts?
Old 07-15-2017, 10:59 PM
  #211
Flatgod's Avatar
Stilll have it. Finally got my built engine back, just assembling everything now. What all is done to your car at this point?
Old 07-16-2017, 12:51 AM
  #212
Got Bewst?
Ah nice! Nothing's changed other than upgrading to a 257 from my 252. Stock LDK bottom end, ported head with some turbo cams. But I do run E47 now.
Old 07-16-2017, 04:05 PM
  #213
Flatgod's Avatar
Sweet, where are you finding E47? Hoping I'll be dropping my engine in car tomorrow. Going to run on 252 this year then once bugs are worked out move up to sx-e 257.
Old 07-16-2017, 04:33 PM
  #214
carloloy's Avatar
new guy here
lowering spring recommendations and where to buy?
Old 07-16-2017, 05:54 PM
  #215
Got Bewst?
I hop across the border with a 55 gallon drum in the back of a truck, fill it with E85 and cut it with pump gas back here.
I love my 257. Needed it because my 252 couldn't keep up with my motor and I was losing a lot of boost after 6000rpm. But I really miss the fun streetability of my 252.
Old 07-16-2017, 05:55 PM
  #216
Got Bewst?
Welcome! Are you going for looks or performance for lowering springs?
Old 07-16-2017, 10:08 PM
  #217
cluelessk's Avatar
Think the consensus is H&R for low and Powell for performance.
Old 07-17-2017, 12:11 AM
  #218
Flatgod's Avatar
Nice. wish i was a little closer to the border. I figure if the 257 is a little laggy I'll run a small shot of NOX to spool it. I don't plan on driving the car a lot, haven't drove it in four years or so.
Old 07-17-2017, 03:02 AM
  #219
Got Bewst?
Haha yeah mine has turned in to a princess. Doesn't see much rain. Just sunny tire burning days. I love my car but done with 4 cylinders to be honest. But I'll roll it till I can get behind the wheel of what I want. Just can't buy a car slower than my Cobalt lmao.
It's really not even the 257 that's laggy. It's the stupid tall gearing of the F35 trans. Hell I can do 125mph in 3rd gear at 8000rpm... if I had an F23 to throw in for shorter gear ratios I probably would.
Old 07-17-2017, 04:28 AM
  #220
Glad you found the issue. Shitty problem but worth fixing. I guess it depends how many miles are on the used beam. Allot of work to possibly have the same issue again.
Powell sells those bushings as well. At one point his were cheaper than the oem ones. But oem may have come down inprice since I last checkedz
Old 07-17-2017, 09:05 AM
  #221
carloloy's Avatar
probably more for looks, also, would i need new struts as well or will my stock ones do? im looking at eibach sportlines right now. thanks guys
Old 07-17-2017, 10:52 AM
  #222
Got Bewst?
The sportlines are a popular spring. You can reuse your old struts as long as they aren't leaking.
Old 07-17-2017, 12:14 PM
  #223
Flatgod's Avatar
Guess I'll see how the F40 works out then.
Old 07-17-2017, 01:29 PM
  #224
tomj77's Avatar
257 isn't that laggy. I actually like it. It broke my trans in a month though lol. Shitloads of power.
Old 07-17-2017, 01:30 PM
  #225
tomj77's Avatar
What the ****? Those Asshate
Quick Reply: Manitoba SS 2017
