Manitoba SS 2018
#55
So 472whp and 354ftq at speed factor with car pulling 4 degrees timing cause the dink didnt use fans first 2 pulls plus it was 26 in the shop so ya it was hot. Picked up 35 to when he used fan last pull. I think I'll be close to 500 in fall if u can get all my timing on a pull
#58
I popped in today, and this is one of the threads which I am pleasantly surprised to see as still going on - albeit slower than in years gone by!
How are you all doing?
I still have my yellow car - I swapped the complete drivetrain from the "spare" SS/TC that I had back in 2015 after I suspect I got a bad update from the new owners of Trifecta... so I don't run their tunes anymore;
I might be the only one out there, but I miss the days where Vince was the guy - his work was stellar.
The attached picture should serve to show what I have been up to:
February 2015: Jonah
March 2017: Jocelyn
March 2017: Jocelyn
#60
March 2017: Jocelyn
March 2017: Jocelyn
#61
as I've understood it something changed, maybe Vince sold the tuning side.
Steve has attitude, and I guess we didn't get off on the right foot... but what ever, I bought in as a dealer under Vince, and before I became a dealer I personally met the guy - I wanted to know the guy I would be making mo ey for was a stand up guy... and I believe he is.
I've been running one of Kevin's tunes (as he puts it "set to stock/gms1 boost levels) for a couple years...
#65
I feel like trifecta has been bottom of the barrel as far as quality of tunes goes and customer service for at least 5 or 6 years now. Really no good reason to go with them unless the running two tunes is a must have for you. I really can’t see a reason for that if you have HPT you can easily throw another tune in place and there is sever very compitant tuners left on the forums.
#66
Vinces tunes were good, somewhat conservative (he never had any engines go on his watch), but good.
I can't say the same for the new guy...
But I am admittedly jaded, from when Vince sold(?) what we know as trifecta, the new owner essetially screwed over all the dealers - making it almost impossible for dealers to get any sort of a deal, and essentially making it better for customers to buy direct.
Then there's the tune quality - which my first hand experience says it wasn't there.
...backstory:
I put charge pipes on my car in late 2014, and sent a data log asking steven(?) if the tune needed an update;
He said he "found an error in Vinces tune", the car ran like an absolute raped ape for about a week (I beat some apparent fast cars with that tune) - but then started periodically smoking. First it would only smoke when idling after being driven for a while, then slowly but surely the smoking got worse (This was just after I passed 160,000). By the spring, I couldn't drive my car because it smoked so bad....
My best guess is that I cracked a ringland.
I swapped drivetrains, but carried over my original turbo in the spring of 2015 (the drivetrain I swapped in was from a white wrecked SS/TC I bought back in 2010; it had something shy of 38,000km on it);
Then just this past spring the original turbo was swapped out for the one which came with the drivetrain I am running - which means I had about 220,000km on the original turbo.
Since doing the drivetrain swap, I have been running one of Kevin's tunes - and even though in his words "you're running stock boost levels", I am fine with it... I mean, this has always been intended as my daily driver, so who cares if there are faster cars out there than me... I can still hold my own.
#67
Just for this year. I'll install the fronts and get it aligned next year.
They're K sports so they're adjustable but cheap. Rides not too much worse. Travel is just reduced.
Still on my Winter wheels.....
#68
here is my story with Stephen.....I got zfr and went to trifecta for a tune. one of my injector seals gave out with machine gun popping so I got opels. of course when I put in opels my trims went pig rich....like -18 to -30 rich. Stephen tried for a fricken month and explained he didn't know why the trims were not straightening out. I figured enough of this **** and I went to term2...he had my trims to almost 0 in one file and my tune perfect in like a week. Stephen doesn't know what he is doing period.
#73
My new personal best as well.
I absolutely botched my 2-3 shift (hammered the rev limiter several times) wasn’t ready to actually have traction all through second. It’s too bad because the run before and immediately after I almost matched this ET with 4-5. More mph and a .2-.3 second worse 60ft.
It got too warm after this and the track was getting slippery from tires lol.
