Ontario E-Test with no Cat
Old Nov 29, 2015 | 01:49 PM
iammancini's Avatar
Sorry if this has been posted, but is it possible to pass etest with no cat. Can an HP Tune place the ECU in a state that reads "ready." Is there anything else that i should be concerned about.
Does anyone know of place to get a zzp or equiv downpipe in toronto area that wont kill me on shipping and a HP tune. ive seen adds on kijiji for a place in kitchener called darkknight tuning. are they any good?
Old Nov 29, 2015 | 01:52 PM
You cant use hptuners to make the computer ready, but you can use this device called an o2 defouler. Google it
Old Nov 29, 2015 | 01:54 PM
iammancini's Avatar
have you passed e-test with this defouler? should i just play it safe and get a highflow cat?
Old Nov 29, 2015 | 02:25 PM
Personally i have not because where im registered does not require testing. But i know others who have had success using it.
Also sometimes with a high flow cat, you still have to use the defouler.
Old Nov 29, 2015 | 03:15 PM
iammancini's Avatar
ok thanks for your help.
one method around would be to swap back to stock cat but that would also require changing back to stock tune i presume
Old Nov 29, 2015 | 03:56 PM
not necessarily. as long as you dont drive it too hard or keep it on for longer than you need to it should be fine to test with the stock downpipe on.
Old Nov 29, 2015 | 04:02 PM
My dp has the bung and it passes the ob2 check I have the turboxs one also of you want a deal with zzp, tomorrow they won't be charging shipping internationally
Old Nov 29, 2015 | 04:06 PM
iammancini's Avatar
ok, still cant decide what route to go. i need to make sure it will pass e test.
Old Nov 29, 2015 | 04:43 PM
Hopefully a Canadian can shine in
Old Nov 29, 2015 | 05:50 PM
iammancini's Avatar
yes, surprised there isn't more info on the subject.
Old Jun 5, 2016 | 08:57 PM
BoostedJ's Avatar
Yes, you can.
I did it on my 3800 swapped Sunfire, passed etest without any issue. (Ontario, Canada)
Old Jun 19, 2016 | 10:33 PM
sLAsh's Avatar
Needed the defouler to get my lsj to pass with the zzp high flow.
pmerritt
Dec 31, 2015 01:30 AM
dennis69
Dec 3, 2015 10:44 PM
NihontoSS
106
Dec 2, 2015 07:51 PM
Zooomer
82
Dec 2, 2015 07:36 PM
dennis69
Nov 29, 2015 08:42 PM
