Raceland coilovers
Originally Posted by tuned08ss
Yet to be proven that these are junk. They're just cheaper than the rest.
blubalt92 (02-12-2016)
Stance and BC aren't great coils either. Infraredline just had one of his Pedders snap pulling into a driveway.
Very few off the shelf coils will actually improve handhanding over FE5 suspension.
#37
Keyword.
Stiff/low does not mean better handing. It may feel more responsive but you need to be able to smoothly control body movement
Honestly BCRacing at its softest setting is slightly stiffer than FE5 and that's what we need is slightly stiffer imo.
#44
Well I own a pair of stance and they are junk to be honest.
Just a fun fact if anyone doesn't know by now Stance suspension and HSD coilover's and made by the same manufacturer and they sell for different prices?...Wait did he just say different prices
#46
I emailed them to get specs on the dampers and spring rates, and asked if swift springs would be interchangeable. The info they sent back was, the spring rate is progressive, and the dampers are valved and basically set to the same spec as stock (didn't specify if same as FE1, FE3 or FE5) they also said that since the damper stiffness is not adjust able they do recommend swapping to a linear spring rate like those from swift springs because they will cause the damper to fail. I wasn't interested in getting them, but wanted more info about them.
#49
lets be honest, most people don't take their cars to a track anyways. these are probably going to be crappy but people want cheap and low so there is a market for them. as for the rest of us that want a little drop and better handling there is koni yellows and yyz
OrangeCoba
01-26-2016 11:31 AM
