2006 Cobalt SS/SC G85 Coupe $4600 USD/$6500 CAD obo
http://images.craigslist.org/00505_i...SN_600x450.jpg
Located just outside Vancouver BC - Can meet at the border for a viewing. 145miles/233km Compression test results 70-75psi per cylinder G85 Package with Recaro Seats & Limited Slip Differential Lowered 1.5" from stock SS (have original springs) Eaton Supercharger w Stock Pulley Injen Cold Air Intake w K&N Filter MadFab Header Exhaust Manifold ZZP 2.5" Downpipe & Cat Ingalls Torque Damper Auto Meter Boost Gauge Tuned with HP Tuners - Can detune for mild driving if needed. Debadged and De-Winged 18" Chevrolet Alloy Wheels - Powdercoated Gloss Black Dunlop 18" Tires with 60% tread Pioneer AVH-X3500BHS with full video & bluetooth all hooked up Recent Work Done: Royal Purple used for every oil change since 47k Supercharger Rebuilt with new ZZP coupling New Pads & Rotors New Red River ZZP Clutch ZZP 2.5" Downpipe/Cat & Madfab Header installed Front Wheel Bearings installed Moog Swaybar Endlinks Installed Solid Shifter Mounts & LNF Solid Shift Cable Mounts Stainless Steel Braided Clutch Housing New MAP Sensor & MAF Sensor Rear Wheel Bearings Installed Timing Chain & Gears WaterPump Chain & Balance Shaft Gears New Battery Full New Fuel Line & Fuel Filter Installed The Bad: A/C Compressor is bad (no A/C)- But have a spare to throw in Drivers side tweeter is crackling Key Fob's are old and stopped working. $50 fix. Spares (I have a big rubbermaid tub to go with it): LS4 75mm Throttle body/Spacer & Tapered intake Spare Passenger Side Fender Spare Set of Side Skirts Radiator/Heat Exchanger Fuse Panel Water Pump Stock Airbox Stock Springs Also have a spare set of 17" OZ Racing SuperTurismo GT wheels with Nitto NT-01 track tires that are also for sale and negotiable - 5 x 100 fit on Cobalts. http://images.craigslist.org/00V0V_7...iU_600x450.jpg http://images.craigslist.org/01010_5...DD_600x450.jpg |
Would you be willing to sell the stock airbox/intake? Having trouble passing emissions and im having a hard time finding a stock intake and airbox for the LSJ.
Not sure what happened, posted in the wrong thread somehow haha
