2006 ss/sc tvs built !!
2006 Cobalt ss/sc Ultra metallic silver $6,500
77,000k miles, second owner since 2007 at 14k miles motor has 200miles since the build car runs and drives just needs the top end in the tune dialed in stuts shocks and springs need replacement as the pedder/ss-tc setup is stagging and tired Engine: 2.1L gen 3 block diamond 10.5:1 coated pistons pauter lsj rods balanced lsj crank with extended keyway m2 race cnc ported head with ferrea 1mm oversized valves 75lb supertech valve springs Ottp stage 4 blower cams arp hrad studs cometic head gasket gm main bearing gm rod bearings TVS1320 rebuilt with motor with 2.3 pulley ls4 throttle boddy ati overdrive dampr ottp 2in lon tube header with 3.5in downpipe zzp 3in exhaust with res. ottp 3.5in intake with dual meth port and AN-10 pvc custom -10 pcv system AIS trunk mount dual 10gph meth kit with snow performance progressive controller dual pass end plate phenolic intake spacer zzp stealth heat exchanger custom flow thru tank 160lb injectors walbro 450 return style fuel system powell rotated mounts solid shifter bushings lnf shifter brackets ky stage 3 clutch zzp stage 1 axles all new ball joints,endlinks, and cabs corbreau forza sport seats dual lock sliders g force 6 point harness powell harness bar 45 psi boost gauge aem wideband aeroforce scan gauge ss/tc wheels with brand new federal rssr tires in 225/40/18 pioneer 1200w amp 12in kicker l7 includes a sleeved lnf block that needs some work spare pauter rods spare lsj crank spare lsj head oe leather ss seats 17in ion wheels with m&h radials in 245/45/17 and anything you can dig up in my garage https://cimg7.ibsrv.net/gimg/www.cob...a4c7667d61.jpg https://cimg1.ibsrv.net/gimg/www.cob...3cc2c188ef.jpg https://cimg3.ibsrv.net/gimg/www.cob...29a87ad607.jpg https://cimg5.ibsrv.net/gimg/www.cob...16ef913bbf.jpg https://cimg7.ibsrv.net/gimg/www.cob...52ba07f55c.jpg https://cimg9.ibsrv.net/gimg/www.cob...4e729ec318.jpg |
Nice setup, glws but you have to post a price. Can be obo after that but you have to put a base asking price or thread will be locked.
You may have posted the price but I can't seem to find it. What are you looking to get out of it?
Originally Posted by Kolt
(Post 7700947)
Originally Posted by jdbaugh1
(Post 7700948)
Your description says TVS rebuilt. What was done to it?
(Post 7700952)
will trade for atv
Originally Posted by HGT
(Post 7701157)
With so much done and invested, why stop short of tuning it?
i even own hpt lol |
(Post 7701187)
With that said, I would pull off all the good parts, put a cheap M62 on it and still get close to your asking price.The TVS will bring $1000-$1300 all day by its self.
It was your engine pic that prompted me to run an AN10 Breather out like that but mine is check valved and I still run an AN8 in. interested in anything |
I'd be interested in some parts potentially like your head(minus the cams), heat exchanger. Not sure if you'd go that deep though
This setup is clean af! If I'd ever been looking for an lsj tjis is exactly what id be looking for
is sell the head for 1500 no cams
fresh valve job new guides bowls blend to new valves and a fresh mill ferrea valves supertech springs PRICE DROPPED |
Checking into plan to make head work with my setup and verify I have support to adjust tune accordingly. Very interested.
One of the OG's. Best of luck with sale
PM'd about head
Nice bolt
Would buy but to far away
