For Sale 2006 ss/sc tvs built !!
Old Oct 22, 2018 | 03:54 PM
advise's Avatar
2006 Cobalt ss/sc Ultra metallic silver $6,500
77,000k miles, second owner since 2007 at 14k miles
motor has 200miles since the build
car runs and drives just needs the top end in the tune dialed in
stuts shocks and springs need replacement as the pedder/ss-tc setup is stagging and tired
Engine:
2.1L gen 3 block
diamond 10.5:1 coated pistons
pauter lsj rods
balanced lsj crank with extended keyway
m2 race cnc ported head with ferrea 1mm oversized valves
75lb supertech valve springs
Ottp stage 4 blower cams
arp hrad studs
cometic head gasket
gm main bearing
gm rod bearings
TVS1320 rebuilt with motor with 2.3 pulley
ls4 throttle boddy
ati overdrive dampr
ottp 2in lon tube header with 3.5in downpipe
zzp 3in exhaust with res.
ottp 3.5in intake with dual meth port and AN-10 pvc
custom -10 pcv system
AIS trunk mount dual 10gph meth kit with snow performance progressive controller
dual pass end plate
phenolic intake spacer
zzp stealth heat exchanger
custom flow thru tank
160lb injectors
walbro 450
return style fuel system
powell rotated mounts
solid shifter bushings
lnf shifter brackets
ky stage 3 clutch
zzp stage 1 axles
all new ball joints,endlinks, and cabs
corbreau forza sport seats
dual lock sliders
g force 6 point harness
powell harness bar
45 psi boost gauge
aem wideband
aeroforce scan gauge
ss/tc wheels with brand new federal rssr tires in 225/40/18
pioneer 1200w amp
12in kicker l7
includes a sleeved lnf block that needs some work
spare pauter rods
spare lsj crank
spare lsj head
oe leather ss seats
17in ion wheels with m&h radials in 245/45/17
and anything you can dig up in my garage
Old Oct 22, 2018 | 04:06 PM
Kolt's Avatar
Nice setup, glws but you have to post a price. Can be obo after that but you have to put a base asking price or thread will be locked.
Old Oct 22, 2018 | 04:07 PM
jdbaugh1's Avatar
You may have posted the price but I can't seem to find it. What are you looking to get out of it?
Old Oct 22, 2018 | 04:12 PM
advise's Avatar
Thanks , fixed
Old Oct 22, 2018 | 04:16 PM
advise's Avatar
7k
Old Oct 22, 2018 | 04:22 PM
jdbaugh1's Avatar
Your description says TVS rebuilt. What was done to it?
Old Oct 22, 2018 | 04:32 PM
advise's Avatar
should put repack, only changed the oil and needle bearing grease
Old Oct 24, 2018 | 08:49 AM
advise's Avatar
will trade for atv
Old Oct 25, 2018 | 09:03 AM
advise's Avatar
Originally Posted by HGT
With so much done and invested, why stop short of tuning it?
lost interest
i even own hpt lol
Old Oct 25, 2018 | 12:04 PM
advise's Avatar
With that said, I would pull off all the good parts, put a cheap M62 on it and still get close to your asking price.The TVS will bring $1000-$1300 all day by its self.
It was your engine pic that prompted me to run an AN10 Breather out like that but mine is check valved and I still run an AN8 in.
not a bad idea like the way you think
interested in anything
Old Oct 25, 2018 | 12:14 PM
jdbaugh1's Avatar
I'd be interested in some parts potentially like your head(minus the cams), heat exchanger. Not sure if you'd go that deep though
Old Oct 25, 2018 | 04:43 PM
Cptnslo's Avatar
This setup is clean af! If I'd ever been looking for an lsj tjis is exactly what id be looking for
Old Oct 26, 2018 | 09:37 AM
advise's Avatar
is sell the head for 1500 no cams
fresh valve job
new guides
bowls blend to new valves
and a fresh mill
ferrea valves
supertech springs
PRICE DROPPED
Old Oct 30, 2018 | 08:20 AM
jdbaugh1's Avatar
Checking into plan to make head work with my setup and verify I have support to adjust tune accordingly. Very interested.
Old Nov 2, 2018 | 05:06 PM
One of the OG's. Best of luck with sale
Old Nov 2, 2018 | 10:02 PM
63 Nova SS's Avatar
Sorry to hear your old car sold. Hope a 16 yr old doesn't trash it in a day.
Old Nov 5, 2018 | 08:07 AM
jdbaugh1's Avatar
PM'd about head
Old Nov 6, 2018 | 11:48 PM
Mrguitarbrett's Avatar
Nice bolt
Would buy but to far away
advise
Oct 3, 2017 11:00 AM
Bass_Waves
Apr 14, 2017 10:41 PM
Bass_Waves
Aug 21, 2016 06:16 PM
KangolRiot
Jun 21, 2012 09:21 AM
StevesBlack06
Mar 22, 2010 04:18 PM
