Options:
Sunroof
Polished aluminum wheels
Limited-slip diff
CD/MP3 Multi-disc Pioneer Stereo
Heated leather seats
F&R Side air bags
Victory red
I'm the only owner of this car.
Issues:
The paint bubbled up in a few places by the rocker panel on the passenger side. I touched this up last year but it could use another touchup. Same with the inner doors and wheel wells but that's pretty common on these.
The dealer backed the car into a pole in like 2008, so the carfax shows an accident.
ABS light is on because I dropped the wheel bearing with the speed sensor plugged in and stripped the sensor out of the hub.
Sunroof doesn't open.
Comes with winter tires on SS/NA 17" wheels.
Full maintenance and repair history available, dating back to its first oil change. I oil sprayed this car every year and as a result it is in MUCH better shape underneath than any other Cobalt I've seen up here.
Has GM Stage 2, GM ported manifold (the rest of the exhaust is stock), and GMPP clutch & flywheel that was done at 91k. Also has GM rubber floor mats.
