Drag Racing Kindle Racing and Dalcorp Racing
Attention avid drag racers with SS/SC's
Old Sep 10, 2009 | 03:04 AM
2K5SS/SC?'s Avatar
What are you guys running for setup as for slicks, mounts, etc? More specifically, what are you doing to prevent transmission failure. Thank you ahead of time.
Old Sep 10, 2009 | 03:16 AM
EXsoccer1921's Avatar
i'm not using slicks or drag radials. but i have made street tires and a 49k mile stock clutch work very well. running ottp stage2 mounts, and a ttr upper mount that i machined to work with the others. theres no wheel hop what so ever. i've also practiced enough to where i can match my hand on the shifter with my feet on the clutch and gas. so as soon as the peddal is in far enough to disengage the clutch, the gear its instantly in the next gear and i'm off again, with a smidge off the gas when i shift. almost like a no lift shift.
i also launch at about 2600
Last edited by EXsoccer1921; Sep 10, 2009 at 03:16 AM. Reason: Automerged Doublepost
Old Sep 10, 2009 | 07:16 PM
Maxim_X's Avatar
I am running Traction bars and poly trany mounts for wheelhop. I'm gona get a upper mount for next season because I still get some hop pulling out of the waterbox.
As far as tires i have BFG T/A DR's 255/50/16.
I also have DSS stg 2's
As far as tranny damage prevention... I don't try to keep it in one piece. I drive like I'm rying to break it. 5k 2 step launches and she holds. I think the clutch will fail before the tranny does.
Old Sep 11, 2009 | 04:24 AM
2K5SS/SC?'s Avatar
Thank you gents for the info. Please let's keep this thread going, I know there are more drag racers out there.
Old Sep 11, 2009 | 04:31 AM
BlkWdoSS's Avatar
TTR upper mount, Poly F&R tranny mounts, DSS stg 2 axles... Blown Tranny!
I get a lil wheel hop, I think mine stemmed from the instance when I snapped the axle and then wore down and blew over a short period of time.
Snapped the axle doing a 4500 RPM preload launch and the E-brake caught on the last notch, part of the axle spun and part didnt, twisted it right off.
l8r,
PD
RaginChopsuey
Oct 27, 2015 01:27 PM
jcalvin1126
Oct 26, 2015 12:31 AM
brandon04
Oct 21, 2015 07:04 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
