Drag Racing Kindle Racing and Dalcorp Racing
Footballs/Bags for Pedders
Old Aug 25, 2011 | 01:39 AM
D-mac's Avatar
I am away from home for 2 weeks and have another event approaching for when i get back
Has anyone successfully found a Football or Drag Bag that fits inside the Pedder springs?
Used to run PeeWee footballs in my stock springs and they worked awesome
Now with Pedders i am squatting way to much on launch
Old Aug 25, 2011 | 01:58 AM
09BlueBaltSS's Avatar
Summit has actual bags for like $80 and u can mount the air fitting in the trunk. I'm thinking about picking up a set
Old Aug 26, 2011 | 06:23 AM
joshcsepegi's Avatar
Are these the helper bags? Edvard the summit part number because I'm ol interested
Old Aug 27, 2011 | 11:13 PM
D-mac's Avatar
Yes ive seen these
But
Will they fit inside the Pedder Springs?
Old Aug 28, 2011 | 12:58 AM
Measure the height and inside diameter of the pedders with the car on the ground then call Air Lift. They will tell you which bag will work for you. You will most likely have to trim back the bump stops to make room for the air line at the top of the bags
Old Aug 28, 2011 | 11:42 AM
Powell Race Parts's Avatar
^^^ this.
Old Sep 18, 2011 | 12:29 PM
D-mac's Avatar
Well well
Turns out the Footballs i ran in my stock springs also fit Pedders
Winning
Old Sep 18, 2011 | 12:54 PM
blu3_v1p3r's Avatar
one of my friends had footballs in his aftermarket springs. I thought he was just nuts.... i guess now i know that other people do this too.
Old Sep 18, 2011 | 01:28 PM
c1_c1rca's Avatar
whats the benefit to this?
Old Sep 18, 2011 | 01:33 PM
Stops the car from transferring weight to the rear and unloading the front suspension on launches = better traction
Old Sep 18, 2011 | 04:04 PM
87gn06gto07irl's Avatar
Do footballs make cornering suck and reduce dd comfort?
Old Sep 18, 2011 | 06:24 PM
D-mac's Avatar
I wouldnt drive around the streets with them inflated
I take almost all the air out for the street
Old Oct 7, 2011 | 01:16 PM
D-mac's Avatar
Removed the footballs lastnight
Will be installing AirLift bags tonight
If they fit great i will post info
Old Oct 11, 2011 | 04:14 AM
FrossB's Avatar
Thread Killer
any new info on those AirLift bags??
Old Oct 11, 2011 | 03:18 PM
x2. Which part # did you get?
Old Oct 11, 2011 | 06:45 PM
D-mac's Avatar
Should be going in maybe tomorrow night
Ran out of time last time
Will update with all info needed
Old Oct 14, 2011 | 09:22 AM
Ronn2005's Avatar
D-mac. I am going to try putting footballs in my rear springs, as soon as my new wheels arrive. I was looking on walmart's sight and noticed there are 2 different size pop warner sizes: Junior and Mitey Might. Which size did you use? I am guessing Mitey Mite?
Good look with the air lift, hope all goes well.
btw: everyone I had this crazy idea, what if I ordered another set of pedder front springs and put them in the rear (no homo). Would that be essentially the same effect as adding air lift bags or footballs?
Josh@ottp
721
Aug 24, 2010 01:13 AM
XTC_916
Mar 29, 2010 01:10 PM
blaSSt
Mar 18, 2010 07:34 PM
lsjwannabe
76
Feb 17, 2010 11:54 PM
