Drag Racing Kindle Racing and Dalcorp Racing
Guess our 1/4 mile times!
Old Jul 10, 2009 | 07:50 PM
FASTL61's Avatar
Well a bunch of us are going to the track soon.Just wanna see what you think some of us will run!
FASTL61-2.2L,5 speed,Intake,Ported TB,LE5 Intake manifold,Ported exhaust manifold,Catless DP,LSJ resonator,Full 2.25 exhaust,weight reduction of about 100 lbs,Last 1/4 mile of 15.40.
Tundraboarder666-2.2L,Auto,Intake,LE5 intake manifold,Header/catless DP,full 2.5 exhaust,Trifecta tuned,No previous track time.
06Blackbalt-2.2L,Auto,Intake,Ported TB,LE5 intake manifold,Ported LSJ exhaust manifold,Catless DP,full 2.5 exhaust,60 wet shot of nitrous,drag radials,weight reduction of about 100 lbs,Last 1/4 mile time of 15.0.
FF_ACE-SS/TC 2 door,Intake,Charge piping,Intercooler,Catless DP,Full catback,Tuned,Dyno @ 305Whp & I think it was 350Wtq,Previous 1/4 mile of 13.1.
Please take all our mods into consideration and post what you think we will run.Will post timeslips and vid later.Thanks for looking!
uh bump!
Old Jul 10, 2009 | 07:51 PM
huckernage's Avatar
fastl61 :
what is your rev lim.
all these mod did a 15,4 right
Old Jul 10, 2009 | 07:54 PM
FASTL61's Avatar
No!My rev limit is stock 6500RPM.My last run was without the manifold and without some porting and bald ass tires pulling 2.2 60ft's.now new soft rubber 2.4 mani larger exhaust collectors and more porting to the exh mani and TB.Not tuned BTW but will be soon by trifecta
Old Jul 10, 2009 | 08:01 PM
slowswap's Avatar
FASTL61-2.2L,5 speed,Intake,Ported TB,LE5 Intake manifold,Ported exhaust manifold,Catless DP,LSJ resonator,Full 2.25 exhaust,weight reduction of about 100 lbs,Last 1/4 mile of 15.40. 15.20
Tundraboarder666-2.2L,Auto,Intake,LE5 intake manifold,Header/catless DP,full 2.5 exhaust,Trifecta tuned,No previous track time. 15.6
06Blackbalt-2.2L,Auto,Intake,Ported TB,LE5 intake manifold,Ported LSJ exhaust manifold,Catless DP,full 2.5 exhaust,60 wet shot of nitrous,drag radials,weight reduction of about 100 lbs,Last 1/4 mile time of 15.0. 14.6 on spray
FF_ACE-SS/TC 2 door,Intake,Charge piping,Intercooler,Catless DP,Full catback,Tuned,Dyno @ 305Whp & I think it was 350Wtq,Previous 1/4 mile of 13.1. 13.0 maybe 12.9
uh bump!
Look at the bold type.
Old Jul 10, 2009 | 08:11 PM
FASTL61's Avatar
sounds about right.Thats exactly what I was thinking on my time.Thanks for your input
oh and ive never ran with the seats out either
Old Jul 10, 2009 | 08:15 PM
Tundraboarder666's Avatar
Yeah this should be a fun night see what we all can do.
Old Jul 10, 2009 | 08:16 PM
huckernage's Avatar
it is my advice from a 14,6 saturn.
My rev is at 7300 why:
hit cut off at 6500 is bad
hit cut off at 7300 is not better
with a rev at 7600, you will shift safely wo hit your rev at 7300. there is a little lag from rpm and what I see in my tach.
last night I put a tune with a 7600 rpm from trifecta in stock G5. R&D
You have to finish full speed in third gear if not lost time to shift in 4th gear.
with a 7300rpm, 7/10 finish on 3th gear and got a 14,7.
Old Jul 10, 2009 | 08:18 PM
FASTL61's Avatar
Hmm interesting
Old Jul 10, 2009 | 08:19 PM
Brandon97Z's Avatar
My 2.4 is set at 7k and i never go into 4th in the quarter....7300 is pushing it for a stock valvetrain
Old Jul 10, 2009 | 08:21 PM
FASTL61's Avatar
Ya when I get tuned im only setting it to 7k just to make sure I dont float any valves
Old Jul 10, 2009 | 08:23 PM
Brandon97Z's Avatar
over 7k is worthless anyways....your not making anymore power.....i'll check on what i top out at 3rd on the way home.
Old Jul 10, 2009 | 08:26 PM
NWAE Cobalt's Avatar
i set mine to 7200 and shift at 7k so i dont actually hit the limiter.
as far as 4th gear goes ive always had to, even on my buddies rims and tires,
Old Jul 10, 2009 | 08:27 PM
FASTL61's Avatar
I usually hit just the top of 3rd or just shift into 4th by the finish line
Old Jul 10, 2009 | 08:31 PM
Brandon97Z's Avatar
I know i don't get outa 3rd till the mid to high 90's range.
smthomas556's Avatar
Good luck tonight guys. I will not be attending.
Old Jul 10, 2009 | 08:32 PM
i gain about 7mph in4th by finish..ive tried holding 3rd and no good, raise your rev limiter a lil and you should be fine without 4th for now.
what was your trap speed before?
i trap at about 95mph
Last edited by NWAE Cobalt; Jul 10, 2009 at 08:32 PM. Reason: Automerged Doublepost
Old Jul 10, 2009 | 08:38 PM
Brandon97Z's Avatar
that may be why then plus i got taller tires then stock
Old Jul 10, 2009 | 08:40 PM
FASTL61's Avatar
trap at 89.Alright im heading out.Will be back with slips and video
Old Jul 10, 2009 | 08:42 PM
good luck!
Old Jul 10, 2009 | 09:24 PM
warrenb213's Avatar
im actually gonna say FASTL61 will match his previous 15.4.
mainly because he'll be forced to shift right where his car is starting to crest the hp peak.
on 18's i finish the quarter in 3rd, on 17's i finish the quarter in 4th. there was that big of a diff between the two tire sizes. With 17's my 60ft's no longer were an issue, I was able to get my 60's around 2.33. my end goal is to have a pair of 16's to throw on this car.
but when i do runs I do em with my car fully loaded out. i do not remove anything. so when i did my 15.8 run i was sitting on a 3000lb Cobalt at least lol. So to be honest, with all my weight adders I'm happy to be where I'm at.
from where I'm at though, I'm done with buying anymore bolt-on engine stuff for a while. Engine performance-wise, I'll be going turbo before I do anything else.
Good luck at the track Fastl61
Old Jul 10, 2009 | 09:28 PM
ya...weight reduction really doesnt do anythign in these cars
Old Jul 10, 2009 | 09:34 PM
The temp here right now is 107 currently lol. Keep that in mind when guessing.
Old Jul 10, 2009 | 11:44 PM
huckernage's Avatar
but work in my case. dont forget I m still on top....
Old Jul 11, 2009 | 02:23 AM
FASTL61's Avatar
Yes,I forgot to factor in that is only got down to 103*F by 10:30 pm.I could only flag a 15.84 with a 2.4 60 ft.Track prep was bleh.I couldnt hook up worth dick out of the whole.It was just too dam hot IAT's were prolly about 120 ish .highest trap though ws 91mph.This gives me time to get tuned then go back once it gets cooler outside.Tundraboarder hit fastest of 15.85 in his auto.FF_ACE could only hit the fastest of 13.60.He had lots of tire spin.Overal it was fun but just to hot so like I said i wont go back till it cools don and by then I should have the tune and nitrous.thanks for the support guys,maybe next time.
Old Jul 11, 2009 | 03:44 AM
Yeah hopefully next time will be better.. Still a good time though
