Drag Racing Kindle Racing and Dalcorp Racing
Ran best time at track tonight
Old Sep 20, 2006 | 11:46 PM
CobaltSS1's Avatar
Well i ran my best time at the track tonight. I ran it with bald ass stock tires, a slipping clutch and and with the mods in my signature. I don't have a scanner so i will type it all out.
R/T- .081
60'- 2.133
330- 5.792
1/8- 8.744
MPH- 83.04
1000- 11.282
1/4- 13.407
MPH- 106.60
I know with some good tires and a new clutch i can get high 12's on current setup.
Old Sep 20, 2006 | 11:54 PM
Rangerondubz's Avatar
Ummmm I dk if it is even possible to run 12's with a Stage 2 and 2.8 pulley but hey prove me wrong and make it happen : )
Old Sep 20, 2006 | 11:57 PM
poppagun's Avatar
I hate you i have the same mods ex the short through and the TD and can only get a 14.1 with a 2.5 60 i guess that TD really helps might have to get me one of those
Old Sep 20, 2006 | 11:58 PM
CobaltSS1's Avatar
well they say slicks can take 4/10 of a second off your time and with a solid clutch i know i am good enough of a driver to get 12's
patathSS's Avatar
A 2.13 on street rubber isgood with that much power. Its going to be tough to shave .4 just with tires and a clutch.
Old Sep 21, 2006 | 12:00 AM
patathSS's Avatar
No way are slicks going to cut .4 off your time if you already have a 2.13 60'
Old Sep 21, 2006 | 12:04 AM
CobaltSS1's Avatar
if i can cut a 1.9 60' i think i can pull a 12.99 only because my buddy's srt traps a little lower then me and pulls 1.9 60's on slicks runs 12.90's. We will see once i buy a set of slicks.
i am looking for a digi cam to post my slip up so ican get on the top 10 list.
Old Sep 22, 2006 | 09:58 PM
STIwannabe's Avatar
If you cut 2/10s off your 60' you wont be 4/10s faster especially because slicks will lower your trap speed.
Old Sep 22, 2006 | 10:36 PM
p7x's Avatar
p7x
R/T- .081
60'- 2.133
330- 5.792
1/8- 8.744
MPH- 83.04
1000- 11.282
1/4- 13.407
MPH- 106.60
very nice run......we all need better clutches.
Old Sep 22, 2006 | 10:37 PM
cvenom2122's Avatar
alot of stage 2 guys r going to surprise you soon enough i will be in 12's next year with 42 pound injectors and 2.8 on supercharger
Old Sep 22, 2006 | 10:45 PM
patathSS's Avatar
ok.....what else are you going to do? How big a shot are you going to run?
Old Sep 23, 2006 | 12:08 AM
Bad06SS's Avatar
Once you put that 2.8" pulley on, you're no longer GM Stage 2 .
Nice times to the poster! What elevation is your track at, and how were the weather conditions?
Old Sep 23, 2006 | 12:41 AM
Asphalt Assault's Avatar
Well the dicussion started with his mods which is more than stage2 and a 2.8 Pulley.
If you can shave time in your 60ft it can more than double at the end of your quarter. a fast trap does not mean a fast time. I have trapped a best 1/4 that actually had a lower trap for the day.
2.13 is very possible. I have got 2.18 and know that it can be done better.
Clutch and tires should make the difference for him to lower his time by 0.4 IMO. the harder we can launch the more we will have at the end. I am getting a 2.8 pulley then I want tires.
FYI - being a guinney pig. I dont think anyone has tried P245/45r17. I hope to get that size in real sticky rubber like the NITTO 555R. After that and then it is back to getting more power or LSD. if we can get a lauch under 2.0 then we are good to go for more power.
cvenom2122's Avatar
fm heat exchanger, hp tuners, up the rev limit 7200 rpms, no cat, centerline 16 pound rims with bf goodrich drag tires, bwoody engine and tranny mounts, bwoody supercooler, and my driver mod and if i dont hit a 12.9 im probably gonna spray lmao! i just gotta prove that 42 pound injectors can make it to 12's then ill up them to 60's
Old Sep 23, 2006 | 12:42 AM
cvenom2122's Avatar
i think that tire size is stock for the ion redline
Old Sep 24, 2006 | 02:29 AM
actually they are 215/45r17 on a redline. Big difference.
I have been looking around seeing other tires that people have been able to fit.
255/50r16 is the same size of 255/45r17 and now that is what I would shoot for. Need a set of 17x8" rims though.
Old Sep 24, 2006 | 02:41 AM
Shortbus's Avatar
Iam running a 245/40/16 on nitto nt55 dr's havent tested em out at the track yet. Might as well so by to my axles though.
Old Sep 24, 2006 | 03:10 AM
245/40/16 on nitto nt55 dr's? is this correct? what are nt55?
245/40r16? Really? they fit well?
I went on the site just now. do you mean the 245/50r16 555r? that I can find on the site.
Old Sep 24, 2006 | 03:35 AM
SilverSS/SC's Avatar
He probably means the 555r , they only have one drag radial . There is a member of this site that runs a 255/50-16 BFG drag radial as well ...I dont remember his screenname though . Theres more room up in there than people think , hehehe
Awesome runs CobaltSS1
Old Sep 24, 2006 | 09:39 AM
patathSS's Avatar
Yeah you can run a pretty tall tire. I run a 235-60r15. Tall tire, just slightly taller than the stock ones.
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
roth
Sep 26, 2015 12:16 PM
