Tell us how you launch with slicks. & 60 Foot Times
Trying to see who has the best technique for launching with slicks and Dot radial drag tires. Give us your launch RPM, 60 ft times. and ET Top speed.
Your car is built almost exactly like mine. 09 SS TC Yellow Aem intake, Dejon Cp, Hahn Catted Downpipe , Jennetty 3 inch exhaust, Hurst short throw, Engalls Stiffy, Ott Mounts , Trifecta Dual Tune
Last edited by mongorat427; Sep 17, 2009 at 05:16 PM. Reason: Automerged Doublepost
There is no best rpm. It depends on the cars setup, tune, track, tire, weather, alot of things. You just have to practice with different styles and techniques till you get it figured out. You can't even stay at the same rpm run to run or day to day, things will always be changing minute to minute. There's been times I have had to lower tire pressure in the staging lanes because someone broke down. Usually after that the track won't hook as good for a bit till it gets more rubber down, unless they spray vht, then your good.
