Yes low 60ft and ET can be done on street tires.gm2 flash
8.949 @81.881mph w/2.116 60 ft (44F temps, 27psi in tires)
slip link
i was a bit quick on the light, but as you can see it can be done. more mods to come . still looking for 8.5ish in the eighth on pump gas. really needing a hptune.
slip link
heat up yer perrelli's as much as possible without using the water box. I back all thw way up to the box with my front tires 2ft in front of the water. then drop the clutch at 4500 and pull the e-brake at the same time to get maximum burn. hit the rev limiter most of the time as well. anyways back to the line. well i tend to launch in the 1800-2300 rpm range.I guess i slip the clutch out and let it roll at the 3rd yellow light and floor it up to top of first, shift at 6800rpm (bout where my torque curve falls) to 2nd. guess that's about it. tire pressure and air temp is important. on this run air temp 1 was 54F and air2 was at 98F. i cool the car between runs (fans and CAC pump are on in staging lanes). guess that's it for my tips. Drag radials, clutch and HD axles in the spring.
